REST API reference
Create a new storage pool
POST /storage/pools
Introduced In: 9.11
Creates a new storage pool using available solid state capacity attached to the nodes specified.
Required properties
The following properties are required in the POST body:
  • name - Name of the new storage pool.
  • nodes[].name or nodes[].uuid - Nodes that can use cache capacity from the new storage pool. Only nodes in the same HA pair can be specified for a given storage pool. Spare cache capacity will be distributed evenly among the specified nodes.
  • capacity.disk_count - Number of SSDs to be used to create the storage pool.
  • storage pool create
Example:
POST /api/storage/pools {"nodes": [{"name": "node1"}, {"name": "node2"}], "name": "storage_pool_1", "capacity": {"disk_count": "4"}}
disk_size
integer
query
False
If set, POST only selects SSDs within five percent of the specified size.
simulate
boolean
query
False
When set to "true", the end point returns a simulated layout of the proposed new storage pool, without changing system state.
  • Introduced in: 9.12
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
capacity
capacity
name
string
Storage pool name.
nodes
array[node_reference]
Nodes that can use this storage pool for their aggregates.
storage_type
string
Storage type for the disks used to create the storage pool.
uuid
string
Storage pool UUID.
Example request
  "capacity": {
    "disks": [
        "disk": {
          "name": "1.0.1"
        "total_size": 0,
        "usable_size": 0
    "remaining": 0,
    "spare_allocation_units": [
        "available_size": 0,
        "node": {
          "name": "node1",
        "size": 0,
        "syncmirror_pool": "string"
    "total": 0,
    "used_allocation_units": [
        "aggregate": {
          "name": "aggr1",
        "current_usage": 0,
        "node": {
          "name": "node1",
  "name": "string",
  "nodes": [
      "name": "node1",
  "storage_type": "string",
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
11206666
Storage pool is unhealthy.
11208658
A storage pool already uses the specified name.
11208660
Disk does not exist.
11208661
Disk is not a spare disk.
11208662
Disk is not an SSD.
11208663
Disk is reserved for core dump.
11208664
Could not determine checksum type of disk.
11208666
Could not determine usable size of disk.
11208668
Could not determine connectivity between controller and disk.
11208670
Could not determine original owner of disk.
11208671
Could not determine SyncMirror pool of disk.
11208673
Could not determine HA mode of node.
11208674
Could not determine HA partner of node.
11208675
Disks specified in the disk list are not visible to node.
11208678
The disk list contains disks from nodes which are not in HA pair.
11208679
Storage pools are not supported on nodes.
11208680
Internal error. Cannot determine configuration for node.
11208681
Node is not online.
11208682
Internal error. Sharing configuration mismatch.
11208684
Unable to share disk.
11208686
Disk cannot be shared.
11208687
Unable to retrieve expected sharing configuration.
11208688
Storage pool create job failed.
11208690
Not all nodes sharing the storage pool view disk as a shared disk.
11208691
Not enough matching spares available.
11208692
A disk list or count is a required parameter for storage pool creation.
11208693
Invalid number of disks specified.
11208698
Internal error. Missing node name.
11208699
Internal error. Missing partner name for node configured for HA.
11208701
Node is a standalone node. Do not specify other nodes with a standalone node.
11208703
Incorrect number of nodes specified. Specify one node or both nodes in an HA pair.
11208704
Specified nodes are not part of HA relationship. Specify one node or both nodes in an HA pair.
11208705
Disk is a data center SSD, which cannot be used in storage pools.
11208706
Disk is a SSD-ZNS, which cannot be used in storage pools.
11215756
Missing a required field for POST request.
string
disk
Reference to the constituent disk object.
name
string
storage_pool_disk
disk
disk
total_size
integer
Raw capacity of the disk, in bytes.
usable_size
integer
Usable capacity of this disk, in bytes.
node
Specifies what node can use this set of allocation units.
name
string
uuid
string
storage_pool_spare_allocation_unit
available_size
integer
The usable capacity of this set of allocation units.
count
integer
The number of spare allocation units on this node.
node
node
size
integer
Size of each allocation unit.
syncmirror_pool
string
The RAID SyncMirror Pool to which this allocation unit is assigned.
aggregate
The aggregate that is using this cache capacity.
name
string
uuid
string
node
The node hosting the aggregate using this set of allocation units.
name
string
uuid
string
storage_pool_used_allocation_unit
aggregate
aggregate
count
integer
The number of allocation units used by this aggregate.
current_usage
integer
The amount of cache space used by this aggregate.
node
node
capacity
disk_count
integer
The number of disks in the storage pool.
disks
array[storage_pool_disk]
Properties of each disk used in the shared storage pool.
remaining
integer
Remaining usable capacity in the flash pool, in bytes.
array[storage_pool_spare_allocation_unit]
Properties of spare allocation units.
total
integer
Total size of the flash pool, in bytes.
array[storage_pool_used_allocation_unit]
Information about the storage pool allocation units participating in the cache tier of an aggregate.
code
string
Argument code
message
string
Message argument
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
health
Properties that outline shared storage pool health.
is_healthy
boolean
Indicates whether the storage pool is able to participate in provisioning operations.
state
string
The state of the shared storage pool.
node_reference
name
string
uuid
string
storage_pool
capacity
capacity
name
string
Storage pool name.
nodes
storage_type
string
uuid
string
Storage pool UUID.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
