REST API reference
Create an event filter rule
Creates an event filter rule to specify criteria for matching events, either by including or excluding specific messages or parameters. This helps you manage and respond to events based on your defined rules.
HTTP method and endpoint
POST /support/ems/filters/{name}/rules
Introduced in
ONTAP 9.6
Required properties
  • type - Enumeration indicating whether the rule is for include or exclude.
  • message_criteria - Message criteria used by a rule to match an event.
  • parameter_criteria - Parameter criteria used by a rule to match an event. Note: At least one pattern needs to be provided for message_criteria and / or parameter_criteria.
  • index - One-based position index of the new rule.
  • event filter rule add
name
string
path
True
Filter name
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
Matching message definitions for the filter. A property must be specified.
parameter_criteria
array[parameter_criteria]
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters.
type
string
Rule type
Example request
  "index": 1,
  "message_criteria": {
    "name_pattern": "callhome.*",
    "severities": "error,informational",
    "snmp_trap_types": "standard|built_in"
  "parameter_criteria": [
      "name_pattern": "vol",
      "value_pattern": "cloud*"
  "type": "include"
Status: 201, Created
num_records
integer
Number of records
records
array[records]
  "num_records": 1,
  "records": [
      "index": 1,
      "type": "include"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
983092
The index of the rule provided is outside the allowed range for the filter provided
983095
The rule index provided is invalid for the filter provided
983113
Default filters cannot be modified or removed
983115
The maximum number of filter rules is reached
983126
A rule requires at least one name_pattern, severities, snmp_trap_types, or parameter pattern to be defined
983127
A property cannot contain a combination of the wildcard characters and other values
983128
An invalid value is provided for the property 'snmp_trap_types'
983146
An invalid value is provided for the property 'severities'
983147
The severities provided are not supported
983155
The provided severities property does not match that of the name_pattern
983156
The provided snmp_trap_types property does not match that of the name_pattern
983157
The provided severities and snmp_trap_types properties do not match those of the name_pattern
983158
The name_pattern provided does not exist
983195
Empty field in parameter_criteria. Both name and value patterns must be specified
983196
name_pattern and value_pattern fields in parameter_criteria are empty
983211
Parameter criteria based filtering is not supported in this version of ONTAP
string
message_criteria
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
parameter_criteria
Criterion used for parameter based filtering
name_pattern
string
Parameter name pattern. Wildcard character '*' is supported.
value_pattern
string
Parameter value pattern. Wildcard character '*' is supported.
ems_filter_rule
Rule for an event filter
index
integer
message_criteria
message_criteria
parameter_criteria
type
string
Rule type
records
index
integer
message_criteria
message_criteria
parameter_criteria
type
string
Rule type
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
