Create an event filter rule
Creates an event filter rule to define criteria for matching events. Use this to organize and filter events based on specific conditions for efficient monitoring and management.
HTTP method and endpoint
POST /support/ems/filters/{name}/rules
Introduced in
ONTAP 9.6
Required properties
message_criteria- Criteria on which a rule is to match an event.
Recommended optional properties
index- One-based position index of the new rule.
Related ONTAP commands
event filter rule add
name |
string |
path |
True |
Filter name |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
Example request
"index": "1",
"message_criteria": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": "3",
"records": [
"index": "1",
"type": "include"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983095 |
The rule index provided is invalid for the filter provided |
983113 |
Default filters cannot be modified or removed |
983115 |
The maximum number of filter rules is reached |
983126 |
A rule requires at least one name_pattern, severities, or snmp_trap_types to be defined |
983127 |
A property cannot contain a combination of the wildcard characters and other values |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severity levels provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
href |
string |
_links
message_criteria
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
ems_filter_rule
Rule for an event filter
index |
integer |
message_criteria |
type |
string |
Rule type |
records
index |
integer |
message_criteria |
type |
string |
Rule type |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
