Create SNMP traphosts
Creates SNMP traphosts to define destinations for SNMP traps from your system. You use this when you want to configure SNMP notifications, ensuring they reach the appropriate monitoring tools.
HTTP method and endpoint
POST /support/snmp/traphosts
Introduced in
ONTAP 9.7
Usage notes
While adding an SNMPv3 traphost, an SNMPv3 user configured in ONTAP must be specified. ONTAP uses this user's credentials to authenticate and/or encrypt traps sent to this SNMPv3 traphost. While adding an SNMPv1/SNMPv2c traphost, SNMPv1/SNMPv2c user or community need not be specified.
Required properties
host- Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
Recommended optional properties
If
hostrefers to an SNMPv3 traphost, the following field is required:-
user- SNMPv3 or User-based Security Model (USM) user.
For an SNMPv1/SNMPv2c traphost, ONTAP automatically uses 'public' if 'public' is configured or no community is configured. Otherwise, ONTAP uses the first configured community.
Related ONTAP commands
system snmp traphost add
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
host |
string |
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost. |
user |
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community. |
Example request
"host": "traphost.example.com",
"user": {
"name": "snmpv3user3"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[snmp_traphost] |
"num_records": 1,
"records": [
"user": {
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8847365 |
Unknown host. |
9043969 |
Duplicate traphost entry. |
9043980 |
IPv6 support is disabled. |
9043991 |
Not a USM user. |
9043993 |
Current cluster version does not support SNMPv3 traps. |
9044001 |
Failed to create SNMPv1 traphost. |
9044002 |
Failed to create SNMPv3 traphost. |
href |
string |
_links
user
name |
string |
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
snmp_traphost
SNMP manager or host machine that receives SNMP traps from ONTAP.
host |
string |
user |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
