REST API reference
Create SNMP traphosts
Creates SNMP traphosts to configure where SNMP traps are sent from your ONTAP system. Use this endpoint to specify an SNMPv3 user for secure trap delivery or leverage default settings for SNMPv1/SNMPv2c traphosts.
HTTP method and endpoint
POST /support/snmp/traphosts
Introduced in
ONTAP 9.7
Usage notes
While adding an SNMPv3 traphost, an SNMPv3 user configured in ONTAP must be specified. ONTAP uses this user's credentials to authenticate and/or encrypt traps sent to this SNMPv3 traphost. While adding an SNMPv1/SNMPv2c traphost, SNMPv1/SNMPv2c user or community need not be specified.
Required properties
  • host - Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
  • If host refers to an SNMPv3 traphost, the following field is required:
    • user - SNMPv3 or User-based Security Model (USM) user.
  • For an SNMPv1/SNMPv2c traphost, ONTAP automatically uses 'public' if 'public' is configured or no community is configured. Otherwise, ONTAP uses the first configured community.
  • system snmp traphost add
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
host
string
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
user
user
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community.
Example request
  "host": "traphost.example.com",
  "user": {
    "name": "snmpv3user3"
Status: 201, Created
num_records
integer
Number of records.
records
array[snmp_traphost]
  "records": [
      "user": {
Status: Default
ONTAP Error Response Codes
Error Code Description
8847365
Unknown host.
9043969
Duplicate traphost entry.
9043980
IPv6 support is disabled.
9043991
Not a USM user.
9043993
Current cluster version does not support SNMPv3 traps.
9044001
Failed to create SNMPv1 traphost.
9044002
Failed to create SNMPv3 traphost.
string
user
name
string
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
  • example: snmpv3user3
  • Introduced in: 9.7
snmp_traphost
SNMP manager or host machine that receives SNMP traps from ONTAP.
host
string
user
user
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
