REST API reference
Create and provision an SVM
Creates and provisions a Storage Virtual Machine (SVM), which is essential for managing and configuring storage resources within your ONTAP environment. Use this endpoint to set up an SVM with specific configurations, like IPspace, CIFS, or NFS settings, depending on your network and storage requirements.
HTTP method and endpoint
POST /svm/svms
Introduced in
ONTAP 9.6
Usage notes
Creates and provisions an SVM. If no IPspace is provided, then the SVM is created on the Default IPspace.
  • The number of parallel SVMs that can be created must not be greater than five.
  • If a sixth SVM POST request is issued, the following error message is generated: "Maximum allowed SVM jobs exceeded. Wait for the existing SVM jobs to complete and try again."
Required properties
  • name - Name of the SVM to be created.
  • ipspace.name or ipspace.uuid - IPspace of the SVM
  • is_space_reporting_logical - Logical Space Reporting parameter of the SVM
  • is_space_enforcement_logical - Logical Space Enforcement parameter of the SVM
  • ip_interfaces - If provided, the following fields are required:
  • ip_interfaces.name - Name of the interface
  • ip_interfaces.ip.address - IP address
  • ip_interfaces.ip.netmask - Netmask length or IP address
  • ip_interfaces.location.broadcast_domain.uuid or ip_interfaces.location.broadcast_domain.name - Broadcast domain name or UUID belonging to the same IPspace of the SVM.
  • subnet.uuid or subnet.name - Either name or UUID of the subnet to create.
  • routes - If provided, the following field is required:
    • routes.gateway - Gateway IP address
  • cifs - If provided, interfaces, routes and DNS must be provided. The following fields are also required:
    • cifs.name - Name of the CIFS server to be created for the SVM.
    • cifs.ad_domain.fqdn - Fully qualified domain name
    • cifs.ad_domain.user - Administrator username
    • cifs.ad_domain.password - User password
  • ldap - If provided, the following fields are required:
    • ldap.servers or ldap.ad_domain - LDAP server list or Active Directory domain
    • ldap.bind_dn - Bind DN
    • ldap.base_dn - Base DN
  • nis - If provided, the following fields are required:
    • nis.servers - NIS servers
    • nis.domain - NIS domain
  • dns - If provided, the following fields are required:
    • dns.servers - Name servers
    • dns.domains - Domains
  • fc_interfaces - If provided, the following fields are required:
    • fc_interfaces.name - Fibre Channel interface name
    • fc_interfaces.data_protocol - Fibre Channel interface data protocol
    • fc_interfaces.location.port.uuid or fc_interfaces.location.port.name and fc_interfaces.location.port.node.name - Either port UUID or port name and node name together must be provided.
  • s3 - If provided, the following field should also be specified:
    • s3.name - Name of the S3 server. If s3.name' is not specified while s3.enabled` is set to 'true', the S3 server will be created with the default name '_S3Server'.
  • auto_enable_analytics - Auto-enable file system analytics on new volumes created in the SVM.
  • auto_enable_activity_tracking - Auto-enable volume activity-tracking on new volumes created in the SVM.
  • storage_limit - Maximum storage permitted on a single SVM.
  • storage_limit_threshold_alert - At what percentage of storage capacity, alert message needs to be sent.
Default property values
If not specified in POST, the following default property values are assigned:
  • language - C.UTF-8
  • ipspace.name - Default
  • snapshot_policy.name - Default
  • subtype - Default ( sync-source if MetroCluster configuration )
  • anti_ransomware_default_volume_state - disabled
  • vserver create
  • vserver add-aggregates
  • network interface create
  • network route create
  • vserver services name-service dns create
  • vserver nfs create
  • vserver services name-service ldap client create
  • vserver cifs create
  • vserver services name-service nis-domain create
  • vserver iscsi create
  • vserver nvme create
  • vserver fcp create
  • vserver services name-service ns-switch create
  • vserver object-store-server create
  • vserver add-protocols
  • vserver remove-protocols
  1. Creates an SVM with default "snapshot_policy"
  POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}}'
  1. Creates an SVM and configures NFS, ISCSI and FCP
  POST "/api/svm/svms" '{"name":"testVs", "nfs":{"enabled":"true"}, "fcp":{"enabled":"true"}, "iscsi":{"enabled":"true"}}'
  1. Creates an SVM and configures NVMe
  POST "/api/svm/svms" '{"name":"testVs", "nvme":{"enabled":"true"}}'
  1. Creates an SVM and configures LDAP
  POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}, "ldap":{"servers":["10.140.101.1","10.140.101.2"], "ad_domain":"abc.com", "base_dn":"dc=netapp,dc=com", "bind_dn":"dc=netapp,dc=com"}}'
  1. Creates an SVM and configures NIS
  POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}, "nis":{"enabled":"true", "domain":"def.com","servers":["10.224.223.130", "10.224.223.131"]}}'
  1. Creates an SVM and configures DNS
  POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}, "dns":{"domains":["abc.com","def.com"], "servers":["10.224.223.130", "10.224.223.131"]}}'
  1. Creates an SVM and configures a LIF
  POST "/api/svm/svms" '{"name":"testVs", "ip_interfaces": [{"name":"lif1", "ip":{"address":"10.10.10.7", "netmask": "255.255.255.0"}, "location":{"broadcast_domain":{"name":"bd1"}, "home_node":{"name":"node1"}}, "service_policy": "default-management"}]}'
  1. Creates an SVM and configures a LIF with IPV6 address
  POST "/api/svm/svms" '{"name":"testVs", "ip_interfaces": [{"name":"lif2", "ip":{"address":"fd22:8b1e:b255:202:2a0:98ff:fe01:7d5b", "netmask":"24"}, "location":{"broadcast_domain":{"name":"bd1"}, "home_node":{"name":"node1"}}, "service_policy": "default-management"}]}'
  1. Creates an SVM and configures CIFS
  POST "/api/svm/svms" '{"name":"testVs", "cifs":{"name":"CIFDOC", "ad_domain":{"fqdn":"abc.def.com", "organizational_unit":"CN=Computers", "user":"cif_admin", "password":"abc123"}}, "ip_interfaces":[{"name":"lif1", "ip":{"address":"10.10.10.7", "netmask": "255.255.255.0"}, "location":{"broadcast_domain":{"name":"bd1"}, "home_node":{"name":"node1"}}, "service_policy": "default-management"}],"routes": [{"destination": {"address": "0.0.0.0", "netmask": "0"}, "gateway": "10.10.10.7"}], "dns":{"domains":["abc.def.com", "def.com"], "servers":["10.224.223.130", "10.224.223.131"]}}'
  1. Creates an SVM and configures an S3 server
  POST "/api/svm/svms" '{"name":"svm5", "s3":{"name":"s3-server-1", "enabled":true}}'
  1. Creates an SVM and disallows NVMe service for the SVM
  POST "/api/svm/svms" '{"name":"testVs", "nvme":{"allowed":"false"}}'
  1. Creates an SVM, allows and configures the NFS service for the SVM
  POST "/api/svm/svms" '{"name":"testVs", "nfs":{"allowed":"true", "enabled":true}}'
  1. Create an SVM and set the max volume limit for the SVM
  POST "/api/svm/svms/" '{"name":"testVs", "max_volumes":"200"}'
  1. Creates an SVM and disallows the NDMP service for the SVM.
  POST "/api/svm/svms" '{"name":"testVs", "ndmp":{"allowed":"false"}}'
  1. Creates an SVM and specifies whether file system analytics is enabled on all newly created volumes in the SVM.
  POST "/api/svm/svms" '{"name":"testVs", "auto_enable_analytics":true}}'
  1. Creates an SVM and specifies whether volume_activity_tracking is enabled on all newly created volumes in the SVM.
  POST "/api/svm/svms" '{"name":"testVs", "auto_enable_activity_tracking":true}}'
  1. Creates an SVM and specifies the maximum storage limit for a single SVM.
  POST "/api/svm/svms" '{"name":"testVs", "storage_limit":"4GB"}'
  1. Creates an SVM and specifies at what percentage of storage capacity an alert message is sent. Default value is 90.
  POST "/api/svm/svms" '{"name":"testVs", "storage_limit":"20GB", "storage_limit_threshold_alert":"95"}'
Learn more
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
aggregates
array[aggregates]
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates.
aggregates_delegated
boolean
This property is true when the administrator has delegated the aggregates for the SVM volumes.
anti_ransomware_auto_switch_duration_without_new_file_extension
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that no new file-extensions are observed in the volume in recent time. This parameter optionally specifies the recent time duration (in days) to be considered during which no new file-extension should be observed in a given volume to automatically switch the anti-ransomware state from '`learning`" to “enabled”.
anti_ransomware_auto_switch_from_learning_to_enabled
boolean
This property specifies whether anti-ransomware state of the volumes in this SVM are automatically switched by the system from “learning” (dry-run) to “enabled” (active) state after sufficient learning.
anti_ransomware_auto_switch_minimum_file_count
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have a minimum file count in “learning” state. This parameter optionally specifies the minimum number of newly created files in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”.
anti_ransomware_auto_switch_minimum_file_extension
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have minimum number of file extensions in “learning” state. This parameter optionally specifies the minimum number of new file extensions in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”.
anti_ransomware_auto_switch_minimum_learning_period
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should be in “learning” state for sufficient time period. This parameter optionally specifies the minimum number of days a given volume should be in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”.
string
Specifies the default Anti-ransomware state of the volumes in the SVM. Default "anti_ransomware_default_volume_state" property is disabled for POST operation. If this value is "disabled", Anti-ransomware protection is disabled by default on the new volumes that are created in the SVM. If this value is "dry_run", Anti-ransomware protection is in learning mode by default on the new volumes that are created in the SVM. When the Anti-ransomware license is not present, this property is ignored and volumes will be created with the "disabled" state.
anti_ransomware_incoming_write_threshold
string
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in GB) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion.
anti_ransomware_incoming_write_threshold_percent
string
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in percentage) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion.
boolean
Specifies whether volume activity tracking is automatically enabled on volumes that are created in the SVM.
boolean
Specifies whether file system analytics is automatically enabled on volumes that are created in the SVM.
cifs
cifs
comment
string
Comment
dns
dns
fc_interfaces
array[fc_interface_svm]
FC Interface for the SVM
fcp
fcp
ip_interfaces
array[ip_interface_svm]
IP interfaces for the SVM
ipspace
ipspace
Either the UUID or name may be supplied on input.
boolean
Indicates whether logical space enforcement for the SVM is enabled.
boolean
Indicates whether logical space reporting for the SVM is enabled.
iscsi
iscsi
language
string
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests.
ldap
ldap
max_volumes
string
This property is used by cluster administrator to specify the limit on maximum number of volumes allowed in the SVM. The value can be either the string "unlimited" or a number.
name
string
The name of the SVM.
ndmp
ndmp
nfs
nfs
nis
nis
nsswitch
nsswitch
Name service switch configuration
number_of_volumes_in_recovery_queue
integer
Number of volumes in the recovery queue.
nvme
nvme
routes
array[network_route_for_svm]
Optional array of routes for the SVM
s3
s3
snapmirror
snapmirror
Specifies attributes for SVM DR protection.
snapshot_policy
snapshot_policy
This is a reference to the Snapshot copy policy.
storage
storage
subtype
string
SVM subtype. The SVM subtype sync_destination is created automatically when an SVM of subtype sync_source is created on the source MetroCluster cluster. A POST request with sync_destination as SVM subtype is invalid.
total_volume_size_in_recovery_queue
integer
Sum of the sizes of the volumes in the recovery queue.
uuid
string
Example request
  "aggregates": [
      "available_size": 10156560384,
      "name": "aggr1",
  "anti_ransomware_default_volume_state": "string",
  "anti_ransomware_incoming_write_threshold": "string",
  "anti_ransomware_incoming_write_threshold_percent": "string",
  "cifs": {
    "ad_domain": {
      "default_site": "string",
      "fqdn": "example.com",
      "organizational_unit": "string",
      "password": "string",
      "user": "string"
    "domain_workgroup": "string",
    "name": "CIFS1"
  "comment": "string",
  "dns": {
    "domains": [
      "example.com",
      "example2.example3.com"
    "servers": [
      "10.224.65.20",
      "2001:db08:a0b:12f0::1"
  "fc_interfaces": [
      "data_protocol": "string",
      "location": {
        "port": {
          "name": "0a",
          "node": {
            "name": "node1"
      "name": "lif1",
  "ip_interfaces": [
      "ip": {
        "address": "10.10.10.7",
        "netmask": "24"
      "location": {
        "broadcast_domain": {
          "name": "bd1",
        "home_node": {
          "name": "node1",
      "name": "lif1",
      "service_policy": "string",
      "services": [
        "data_nfs"
      "subnet": {
        "name": "subnet1",
  "ipspace": {
    "name": "exchange",
  "language": "c.utf_8",
  "ldap": {
    "ad_domain": "string",
    "base_dn": "string",
    "bind_dn": "string",
    "servers": [
      "string"
  "max_volumes": "string",
  "name": "svm1",
  "nis": {
    "domain": "string",
    "servers": [
      "string"
  "nsswitch": {
    "group": [
      "string"
    "hosts": [
      "string"
    "namemap": [
      "string"
    "netgroup": [
      "string"
    "passwd": [
      "string"
  "number_of_volumes_in_recovery_queue": 0,
  "routes": [
      "destination": {
        "netmask": "24"
      "gateway": "10.1.1.1"
  "s3": {
    "certificate": {
      "name": "cert1",
    "default_unix_user": "string",
    "default_win_user": "string",
    "name": "s3-server-1"
  "snapmirror": {
    "protected_volumes_count": 0
  "snapshot_policy": {
    "name": "default",
  "storage": {
    "allocated": 0,
    "available": 0,
    "used_percentage": 0
  "subtype": "string",
  "total_volume_size_in_recovery_queue": 0,
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error codes Description
2621580
Cannot specify options other than SVM name, comment and ipspace for a Vserver that is being configured as the destination for SVM DR.
2621634
"sync-source" SVM can only be created in a MetroCluster configuration.
2621657
"sync-destination" SVM can only be created by the system.
13434884
Cannot create an SVM because of incorrect fields.
13434885
Non-UTF8 language(s) not supported.
13434888
IPspace UUID and IPspace name mismatch.
13434889
Internal Error. Wait and retry.
13434894
13434908
Invalid SVM name. The name is already in use by another SVM, IPSpace or cluster.
13434909
Internal Error. Failed to identify the aggregate to host SVM root volume.
13434910
Internal Error. Failed to allocate new SVM ID.
13434911
Invalid SVM name. Maximum supported length is 41 if SVM is of type \"sync-source\", otherwise 47.
13434912
Failed to find IPspace.
13434913
Internal error: Failed to check if an SVM create operation is in progress. Contact technical support for assistance.
13434914
Request to create the root volume of the SVM failed because there is not enough space in specified aggregate.
13434915
Failed to unlock the SVM because SVM create or delete job is in progress. Wait a few minutes, and then try the command again.
13434916
SVM is in the process of being created. Wait a few minutes, and then try the command again.
13434917
SVM creation successful.
13434918
IPspace name not provided for creating an SVM.
string
aggregates
available_size
integer
Space available, in bytes.
name
string
uuid
string
certificate
Support for this field will be removed in a future release. Please use /svm/svms/{svm.uuid}/web for this field. Certificate for incoming TLS connection requests.
name
string
Certificate name
uuid
string
Certificate UUID
ad_domain
default_site
string
The default site used by LIFs that do not have a site membership.
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server.
password
string
The account password used to add this CIFS server to the Active Directory. This is not audited. Valid in POST only.
user
string
The user account used to add this CIFS server to the Active Directory. Valid in POST only.
cifs
ad_domain
ad_domain
allowed
boolean
If this is set to true, an SVM administrator can manage the CIFS service. If it is false, only the cluster administrator can manage the service.
domain_workgroup
string
The NetBIOS name of the domain or workgroup associated with the CIFS server.
enabled
boolean
If allowed, setting to true enables the CIFS service.
name
string
The NetBIOS name of the CIFS server.
dns
domains
array[string]
A list of DNS domains. Domain names have the following requirements:
  • The name must contain only the following characters: A through Z, a through z, 0 through 9, ".", "-" or "_".
  • The first character of each label, delimited by ".", must be one of the following characters: A through Z or a through z or 0 through 9.
  • The last character of each label, delimited by ".", must be one of the following characters: A through Z, a through z, or 0 through 9.
  • The top level domain must contain only the following characters: A through Z, a through z.
  • The system reserves the following names:"all", "local", and "localhost".
servers
array[string]
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses.
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
location
The location of the Fibre Channel interface is defined by the location of its port.
port
fc_port_reference
fc_interface_svm
data_protocol
string
The data protocol for which the Fibre Channel interface is configured.
location
location
name
string
The name of the Fibre Channel interface.
uuid
string
The unique identifier of the Fibre Channel interface.
fcp
allowed
boolean
If this is set to true, an SVM administrator can manage the FCP service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the FCP service.
ip
IP information
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0).
broadcast_domain
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
home_node
name
string
uuid
string
location
Home_node is optional.
broadcast_domain
broadcast_domain
home_node
home_node
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
name
string
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the subnet.
ip_interface_svm
Interface parameters. Name and home_node are optional.
ip
ip
IP information
location
location
name
string
The name of the interface (optional).
service_policy
string
Built-in service policies for SVMs.
services
array[string]
The services associated with the interface.
subnet
ip_subnet_reference
uuid
string
The UUID that uniquely identifies the interface.
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
iscsi
allowed
boolean
If this is set to true, an SVM administrator can manage the iSCSI service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the ISCSI service.
ldap
ad_domain
string
This parameter specifies the name of the Active Directory domain used to discover LDAP servers for use by this client. This is mutually exclusive with servers during POST.
base_dn
string
Specifies the default base DN for all searches.
bind_dn
string
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint.
enabled
boolean
Enable LDAP? Setting to true creates a configuration if not already created.
restrict_discovery_to_site
boolean
Specifies whether or not LDAP server discovery is restricted to site-scope.
servers
array[string]
ndmp
allowed
boolean
If this is set to true, an SVM administrator can manage the NDMP service. If it is false, only the cluster administrator can manage the service.
nfs
allowed
boolean
If this is set to true, an SVM administrator can manage the NFS service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the NFS service.
nis
domain
string
The NIS domain to which this configuration belongs.
enabled
boolean
Enable NIS? Setting to true creates a configuration if not already created.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
nsswitch
group
array[string]
Group sources
hosts
array[string]
Host sources
namemap
array[string]
NameMap sources
netgroup
array[string]
NetGroup sources
passwd
array[string]
Password sources
nvme
allowed
boolean
If this is set to true, an SVM administrator can manage the NVMe service. If it is false, only the cluster administrator can manage the service.
enabled
boolean
If allowed, setting to true enables the NVMe service.
qos_adaptive_policy_group_template
This optionally specifies which QoS adaptive policy group to apply to the SVM as a template. This policy group will then be assigned to volumes created or rehosted into this SVM. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs) that adjust based on the volume allocated space or used space.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos_policy
This optionally specifies which QoS policy group to apply to the Vserver. This policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
max_throughput_iops
integer
max_throughput_mbps
integer
min_throughput_iops
integer
min_throughput_mbps
integer
name
string
uuid
string
ip_info
IP information
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
name
string
Certificate name
uuid
string
Certificate UUID
s3
certificate
certificate
default_unix_user
string
Specifies the default UNIX user for NAS Access.
default_win_user
string
Specifies the default Windows user for NAS Access.
enabled
boolean
Specifies whether or not to enable S3. Setting this value to true creates a service if one is not yet created.
is_http_enabled
boolean
Specifies whether HTTP is enabled on the S3 server. By default, HTTP is disabled on the S3 server.
is_https_enabled
boolean
Specifies whether HTTPS is enabled on the S3 server. By default, HTTPS is enabled on the S3 server.
name
string
Specifies the name of the S3 server. A server name length can range from 1 to 253 characters and can only contain the following combination of characters 0-9, A-Z, a-z, ".", and "-".
port
integer
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80.
secure_port
integer
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443.
snapmirror
is_protected
boolean
Specifies whether the SVM is a SnapMirror source SVM, using SnapMirror to protect its data.
integer
Specifies the number of SVM DR protected volumes in the SVM.
snapshot_policy
name
string
uuid
string
storage
allocated
integer
Total size of the volumes in SVM, in bytes.
available
integer
Currently available storage capacity in SVM, in bytes.
limit
integer
Maximum storage permitted on a single SVM, in bytes.
integer
Indicates at what percentage of storage capacity an alert message is sent. The default value is 90.
limit_threshold_exceeded
boolean
Indicates whether the total storage capacity exceeds the alert percentage.
used_percentage
integer
The percentage of storage capacity used.
svm
aggregates
array[aggregates]
boolean
integer
boolean
integer
integer
integer
string
string
string
boolean
boolean
cifs
cifs
comment
string
Comment
dns
dns
fc_interfaces
fcp
fcp
ip_interfaces
ipspace
ipspace
boolean
boolean
iscsi
iscsi
language
string
ldap
ldap
max_volumes
string
name
string
ndmp
ndmp
nfs
nfs
nis
nis
nsswitch
nsswitch
integer
nvme
nvme
routes
s3
s3
snapmirror
snapmirror
snapshot_policy
snapshot_policy
storage
storage
subtype
string
integer
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
