Create and provision an SVM
Creates and provisions a Storage Virtual Machine (SVM) to manage and isolate storage resources effectively. This operation allows you to define network interfaces, protocols, and services tailored to your storage needs, supporting diverse configurations and integrations.
HTTP method and endpoint
POST /svm/svms
Introduced in
ONTAP 9.6
Usage notes
Creates and provisions an SVM. If no IPspace is provided, then the SVM is created on the Default IPspace.
The number of parallel SVMs that can be created must not be greater than five.
If a sixth SVM POST request is issued, the following error message is generated: "Maximum allowed SVM jobs exceeded. Wait for the existing SVM jobs to complete and try again."
Required properties
name- Name of the SVM to be created.
Recommended optional properties
ipspace.nameoripspace.uuid- IPspace of the SVM -
ip_interfaces- If provided, the following fields are required: -
ip_interfaces.name- Name of the interface -
ip_interfaces.ip.address- IP address -
ip_interfaces.ip.netmask- Netmask length or IP address -
ip_interfaces.location.broadcast_domain.uuidorip_interfaces.location.broadcast_domain.name- Broadcast domain name or UUID belonging to the same IPspace of the SVM. -
routes- If provided, the following field is required:-
routes.gateway- Gateway IP address
cifs- If provided, interfaces, routes and DNS must be provided. The following fields are also required:-
cifs.name- Name of the CIFS server to be created for the SVM. -
cifs.ad_domain.fqdn- Fully qualified domain name -
cifs.ad_domain.user- Administrator username -
cifs.ad_domain.password- User password
ldap- If provided, the following fields are required:-
ldap.serversorldap.ad_domain- LDAP server list or Active Directory domain -
ldap.bind_dn- Bind DN -
ldap.base_dn- Base DN
nis- If provided, the following fields are required:-
nis.servers- NIS servers -
nis.domain- NIS domain
dns- If provided, the following fields are required:-
dns.servers- Name servers -
dns.domains- Domains
fc_interfaces- If provided, the following fields are required:-
fc_interfaces.name- Fibre Channel interface name -
fc_interfaces.data_protocol- Fibre Channel interface data protocol -
fc_interfaces.location.port.uuidorfc_interfaces.location.port.nameandfc_interfaces.location.port.node.name- Either port UUID or port name and node name together must be provided.
s3- If provided, the following field should also be specified:-
s3.name- Name of the S3 server. Ifs3.name' is not specified whiles3.enabled` is set to 'true', the S3 server will be created with the default name '_S3Server'.
Default property values
If not specified in POST, the following default property values are assigned:
language- C.UTF-8 -
ipspace.name- Default -
snapshot_policy.name- Default -
subtype- Default ( sync-source if MetroCluster configuration )
Related ONTAP commands
vserver create -
vserver add-aggregates -
network interface create -
network route create -
vserver services name-service dns create -
vserver nfs create -
vserver services name-service ldap client create -
vserver cifs create -
vserver services name-service nis-domain create -
vserver iscsi create -
vserver nvme create -
vserver fcp create -
vserver services name-service ns-switch create -
vserver object-store-server create -
vserver add-protocols -
vserver remove-protocols
Creates an SVM with default "snapshot_policy"
POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}}'
Creates an SVM and configures NFS, ISCSI and FCP
POST "/api/svm/svms" '{"name":"testVs", "nfs":{"enabled":"true"}, "fcp":{"enabled":"true"}, "iscsi":{"enabled":"true"}}'
Creates an SVM and configures NVMe
POST "/api/svm/svms" '{"name":"testVs", "nvme":{"enabled":"true"}}'
Creates an SVM and configures LDAP
POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}, "ldap":{"servers":["10.140.101.1","10.140.101.2"], "ad_domain":"abc.com", "base_dn":"dc=netapp,dc=com", "bind_dn":"dc=netapp,dc=com"}}'
Creates an SVM and configures NIS
POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}, "nis":{"enabled":"true", "domain":"def.com","servers":["10.224.223.130", "10.224.223.131"]}}'
Creates an SVM and configures DNS
POST "/api/svm/svms" '{"name":"testVs", "snapshot_policy":{"name":"default"}, "dns":{"domains":["abc.com","def.com"], "servers":["10.224.223.130", "10.224.223.131"]}}'
Creates an SVM and configures a LIF
POST "/api/svm/svms" '{"name":"testVs", "ip_interfaces": [{"name":"lif1", "ip":{"address":"10.10.10.7", "netmask": "255.255.255.0"}, "location":{"broadcast_domain":{"name":"bd1"}, "home_node":{"name":"node1"}}, "service_policy": "default-management"}]}'
Creates an SVM and configures a LIF with IPV6 address
POST "/api/svm/svms" '{"name":"testVs", "ip_interfaces": [{"name":"lif2", "ip":{"address":"fd22:8b1e:b255:202:2a0:98ff:fe01:7d5b", "netmask":"24"}, "location":{"broadcast_domain":{"name":"bd1"}, "home_node":{"name":"node1"}}, "service_policy": "default-management"}]}'
Creates an SVM and configures CIFS
POST "/api/svm/svms" '{"name":"testVs", "cifs":{"name":"CIFDOC", "ad_domain":{"fqdn":"abc.def.com", "organizational_unit":"CN=Computers", "user":"cif_admin", "password":"abc123"}}, "ip_interfaces":[{"name":"lif1", "ip":{"address":"10.10.10.7", "netmask": "255.255.255.0"}, "location":{"broadcast_domain":{"name":"bd1"}, "home_node":{"name":"node1"}}, "service_policy": "default-management"}],"routes": [{"destination": {"address": "0.0.0.0", "netmask": "0"}, "gateway": "10.10.10.7"}], "dns":{"domains":["abc.def.com", "def.com"], "servers":["10.224.223.130", "10.224.223.131"]}}'
Creates an SVM and configures an S3 server
POST "/api/svm/svms" '{"name":"svm5", "s3":{"name":"s3-server-1", "enabled":true}}'
Creates an SVM and disallows NVMe service for the SVM
POST "/api/svm/svms" '{"name":"testVs", "nvme":{"allowed":"false"}}'
Creates an SVM, allows and configures the NFS service for the SVM
POST "/api/svm/svms" '{"name":"testVs", "nfs":{"allowed":"true", "enabled":true}}'
Create an SVM and set the max volume limit for the SVM
POST "/api/svm/svms/" '{"name":"testVs", "max_volumes":"200"}'
Learn more
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
aggregates |
array[aggregates] |
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates. |
aggregates_delegated |
boolean |
This property is true when the administrator has delegated the aggregates for the SVM volumes. |
cifs |
comment |
string |
Comment |
dns |
fc_interfaces |
array[fc_interface_svm] |
FC Interface for the SVM |
fcp |
ip_interfaces |
array[ip_interface_svm] |
IP interfaces for the SVM |
ipspace |
Either the UUID or name may be supplied on input. |
iscsi |
language |
string |
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests. |
ldap |
max_volumes |
string |
This property is used by cluster administrator to specify the limit on maximum number of volumes allowed in the SVM. The value can be either the string "unlimited" or a number. |
name |
string |
The name of the SVM. |
nfs |
nis |
nsswitch |
Name service switch configuration |
nvme |
routes |
array[network_route_for_svm] |
Optional array of routes for the SVM |
s3 |
snapmirror |
Specifies attributes for SVM DR protection. |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
subtype |
string |
SVM subtype. The SVM subtype sync_destination is created automatically when an SVM of subtype sync_source is created on the source MetroCluster cluster. A POST request with sync_destination as SVM subtype is invalid. |
uuid |
string |
volume_efficiency_policy |
This is a reference to the volume efficiency policy. |
Example request
"aggregates": [
"name": "aggr1",
"cifs": {
"ad_domain": {
"fqdn": "example.com",
"organizational_unit": "string",
"password": "string",
"user": "string"
"name": "CIFS1"
"comment": "string",
"dns": {
"domains": [
"example.com",
"example2.example3.com"
"servers": [
"10.224.65.20",
"2001:db08:a0b:12f0::1"
"fc_interfaces": [
"data_protocol": "string",
"location": {
"port": {
"name": "0a",
"node": {
"name": "node1"
"name": "lif1",
"ip_interfaces": [
"ip": {
"address": "10.10.10.7",
"netmask": "24"
"location": {
"broadcast_domain": {
"name": "bd1",
"home_node": {
"name": "node1",
"name": "lif1",
"service_policy": "string",
"services": [
"data_nfs"
"ipspace": {
"name": "exchange",
"language": "c.utf_8",
"ldap": {
"ad_domain": "string",
"base_dn": "string",
"bind_dn": "string",
"servers": [
"string"
"max_volumes": "string",
"name": "svm1",
"nis": {
"domain": "string",
"servers": [
"string"
"nsswitch": {
"group": [
"string"
"hosts": [
"string"
"namemap": [
"string"
"netgroup": [
"string"
"passwd": [
"string"
"routes": [
"destination": {
"netmask": "24"
"gateway": "10.1.1.1"
"s3": {
"certificate": {
"name": "cert1",
"name": "s3-server-1"
"snapmirror": {
"protected_volumes_count": 0
"snapshot_policy": {
"name": "default",
"subtype": "string",
"uuid": "02c9e252-41be-11e9-81d5-00a0986138f7",
"volume_efficiency_policy": {
"name": "default",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
2621580 |
Cannot specify options other than SVM name, comment and ipspace for a Vserver that is being configured as the destination for SVM DR. |
2621634 |
"sync-source" SVM can only be created in a MetroCluster configuration. |
2621657 |
"sync-destination" SVM can only be created by the system. |
13434884 |
Cannot create an SVM because of incorrect fields. |
13434885 |
Non-UTF8 language(s) not supported. |
13434888 |
IPspace UUID and IPspace name mismatch. |
13434889 |
Internal Error. Wait and retry. |
13434894 |
Maximum allowed SVM jobs exceeded. Wait for the existing SVM jobs to complete and try again. |
13434908 |
Invalid SVM name. The name is already in use by another SVM, IPSpace or cluster. |
13434909 |
Internal Error. Failed to identify the aggregate to host SVM root volume. |
13434910 |
Internal Error. Failed to allocate new SVM ID. |
13434911 |
Invalid SVM name. Maximum supported length is 41 if SVM is of type \"sync-source\", otherwise 47. |
13434912 |
Failed to find IPspace. |
13434913 |
Internal error: Failed to check if an SVM create operation is in progress. Contact technical support for assistance. |
13434914 |
Request to create the root volume of the SVM failed because there is not enough space in specified aggregate. |
13434915 |
Failed to unlock the SVM because SVM create or delete job is in progress. Wait a few minutes, and then try the command again. |
13434916 |
SVM is in the process of being created. Wait a few minutes, and then try the command again. |
13434917 |
SVM creation successful. |
13434918 |
IPspace name not provided for creating an SVM. |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
certificate
Certificate for incoming TLS connection requests.
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ad_domain
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. |
organizational_unit |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. |
password |
string |
The account password used to add this CIFS server to the Active Directory. This is not audited. Valid in POST only. |
user |
string |
The user account used to add this CIFS server to the Active Directory. Valid in POST only. |
cifs
ad_domain |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the CIFS service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the CIFS service. |
name |
string |
The NetBIOS name of the CIFS server. |
dns
domains |
array[string] |
A list of DNS domains. Domain names have the following requirements:
servers |
array[string] |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses. |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
location
The location of the Fibre Channel interface is defined by the location of its port.
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
fc_interface_svm
data_protocol |
string |
The data protocol for which the Fibre Channel interface is configured. |
location |
The location of the Fibre Channel interface is defined by the location of its port. |
name |
string |
The name of the Fibre Channel interface. |
uuid |
string |
The unique identifier of the Fibre Channel interface. |
fcp
allowed |
boolean |
If this is set to true, an SVM administrator can manage the FCP service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the FCP service. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). |
broadcast_domain
Broadcast domain UUID along with a readable name.
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
name |
string |
uuid |
string |
location
Home_node is optional.
broadcast_domain |
Broadcast domain UUID along with a readable name. |
home_node |
ip_interface_svm
Interface parameters. Name and home_node are optional.
ip |
IP information |
location |
Home_node is optional. |
name |
string |
The name of the interface (optional). |
service_policy |
string |
Built-in service policies for SVMs. |
services |
array[string] |
The services associated with the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
iscsi
allowed |
boolean |
If this is set to true, an SVM administrator can manage the iSCSI service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the ISCSI service. |
ldap
ad_domain |
string |
This parameter specifies the name of the Active Directory domain
used to discover LDAP servers for use by this client.
This is mutually exclusive with |
base_dn |
string |
Specifies the default base DN for all searches. |
bind_dn |
string |
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint. |
enabled |
boolean |
Enable LDAP? Setting to true creates a configuration if not already created. |
servers |
array[string] |
nfs
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NFS service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the NFS service. |
nis
domain |
string |
The NIS domain to which this configuration belongs. |
enabled |
boolean |
Enable NIS? Setting to true creates a configuration if not already created. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
nsswitch
group |
array[string] |
Group sources |
hosts |
array[string] |
Host sources |
namemap |
array[string] |
NameMap sources |
netgroup |
array[string] |
NetGroup sources |
passwd |
array[string] |
Password sources |
nvme
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NVMe service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the NVMe service. |
qos_policy
This optionally specifies which QoS policy group to apply to the Vserver. This policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
ip_info
IP information
address |
string |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
s3
certificate |
Specifies the certificate that will be used for creating HTTPS connections to the S3 server. |
enabled |
boolean |
Specifies whether or not to enable S3. Setting this value to true creates a service if one is not yet created. |
is_http_enabled |
boolean |
Specifies whether HTTP is enabled on the S3 server. By default, HTTP is disabled on the S3 server. |
is_https_enabled |
boolean |
Specifies whether HTTPS is enabled on the S3 server. By default, HTTPS is enabled on the S3 server. |
name |
string |
Specifies the name of the S3 server. A server name length can range from 1 to 253 characters and can only contain the following combination of characters 0-9, A-Z, a-z, ".", and "-". |
port |
integer |
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. |
secure_port |
integer |
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. |
snapmirror
is_protected |
boolean |
Specifies whether the SVM is a SnapMirror source SVM, using SnapMirror to protect its data. |
protected_volumes_count |
integer |
Specifies the number of SVM DR protected volumes in the SVM. |
snapshot_policy
name |
string |
uuid |
string |
name |
string |
Name of the volume efficiency policy |
uuid |
string |
Unique identifier of the volume efficiency policy. |
svm
aggregates |
array[aggregates] |
boolean |
cifs |
comment |
string |
Comment |
dns |
fc_interfaces |
fcp |
ip_interfaces |
ipspace |
iscsi |
language |
string |
ldap |
max_volumes |
string |
name |
string |
nfs |
nis |
nsswitch |
nvme |
routes |
s3 |
snapmirror |
snapshot_policy |
subtype |
string |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
