Support EMS endpoint overview
Overview
The Event Management System (EMS) collects and processes events, and sends notification of the events through various reporting mechanisms. The following endpoints defined under '/support/ems', allow you to query a list of observed events, and configure which events you handle and how you are notified:
/support/ems
/support/ems/events
/support/ems/messages
/support/ems/filters
/support/ems/filters/{name}/rules
/support/ems/filters/{name}/rules/{index}
/support/ems/destinations
/support/ems/destinations/{name}
Configuring an email destination
The following example configures EMS to send a support email when a WAFL event is observed with an error severity.
Configure the system-wide email parameters
# The API:
PATCH /support/ems
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_config_patch.txt"
test_ems_config_patch.txt(body):
"mail_from": "administrator@mycompany.com",
"mail_server": "smtp@mycompany.com"
# The response:
200 OK
Configuring a filter with an enclosed rule
# The API:
POST /support/ems/filters
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_post.txt"
test_ems_filters_post.txt(body):
"name": "critical-wafl",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,error,alert"
# The response:
201 Created
Setting up an email destination
# The API:
POST /support/ems/destinations
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_dest_post.txt"
test_ems_dest_post.txt(body):
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
{ "name" : "critical-wafl" }
# The response:
201 Created
