Manage EMS configuration
Configure general parameters of the Event Management System (EMS) to tailor notifications and alerts within your environment. Use these endpoints to set system-wide email parameters and retrieve current EMS configurations.
Overview
This endpoint is used to configure general parameters of the Event Management System (EMS).
Configuring the system-wide email parameters
# The API:
PATCH /support/ems
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_config_patch.txt"
test_ems_config_patch.txt(body):
"mail_from": "administrator@mycompany.com",
"mail_server": "mycompany.com",
"mail_server_user": "smtp"
# The response:
200 OK
Retrieving the EMS configuration
The following example retrieves EMS configuration for the cluster.
# The API:
GET /support/ems
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json"
# The response:
200 OK
"mail_from": "admin@localhost",
"mail_server": "localhost",
"pubsub_enabled": true,
"href": "/api/support/ems"
