Delete a share-level ACL on a CIFS share
Deletes a share-level ACL on a CIFS share when access control needs to be removed or reconfigured.
HTTP method and endpoint
DELETE /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver cifs share access-control delete
share |
string |
path |
True |
Share name |
user_or_group |
string |
path |
True |
User or group name |
type |
string |
path |
True |
User or group type |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
