REST API reference
Delete a share-level ACL on a CIFS share
Deletes a share-level ACL on a CIFS share when access control needs to be removed or reconfigured.
HTTP method and endpoint
DELETE /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Introduced in
ONTAP 9.6
  • vserver cifs share access-control delete
share
string
path
True
Share name
user_or_group
string
path
True
User or group name
type
string
path
True
User or group type
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
