REST API reference
Delete an S3 bucket lifecycle rule
Deletes a lifecycle rule configuration for an S3 bucket when you no longer need the rule to manage object lifecycles.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced in
ONTAP 9.13
Usage notes
Deletes the S3 bucket lifecycle rule configuration.
  • vserver object-store-server bucket lifecycle-management-rule delete
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
name
string
path
True
The unique identifier of the bucket lifecycle_management rule.
svm.uuid
string
path
True
  • Introduced in: 9.14
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error code Message
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92406123
"Expiration is supported on object store volumes only, bucket on Vserver is not an object store volume.";
92406139
"Lifecycle Management rule for bucket in Vserver with action is a stale entry. Contact technical support for assistance.";
92406141
"Lifecycle Management rule for bucket in Vserver with action cannot have expired_object_delete_marker disabled. To disable expired_object_delete_marker, run vserver object-store-server bucket lifecycle-management-rule delete";
92406144
"Cannot delete fabriclink relationship between bucket A and bucket B. Reason : {2}.";
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
