REST API reference
Delete an S3 bucket lifecycle rule
Removes the lifecycle rule configuration for an S3 bucket. Use this when you need to delete lifecycle management policies that are no longer needed.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced in
ONTAP 9.13
Usage notes
Deletes the S3 bucket lifecycle rule configuration.
  • vserver object-store-server bucket lifecycle-management-rule delete
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
name
string
path
True
The unique identifier of the bucket lifecycle_management rule.
svm.uuid
string
path
True
  • Introduced in: 9.14
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error code Message
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92406139
"Lifecycle Management rule for bucket in Vserver with action is a stale entry. Contact technical support for assistance.";
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
