REST API reference
Delete a portset
Deletes a portset to remove it from your configuration when it's no longer needed.
HTTP method and endpoint
DELETE /protocols/san/portsets/{uuid}
Introduced in
ONTAP 9.9
  • lun portset delete
uuid
string
path
True
The unique identifier of the portset.
allow_delete_while_bound
boolean
query
False
Allows deletion of a portset that is bound to an igroup.
Deleting a portset can expand the set of LIFs through which a LUN is available.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374063
An attempt was made to delete a portset that is bound to an initiator group without using query parameter allow_delete_while_bound.
5374908
The portset does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
