Delete a portset
Deletes a portset to remove it from your configuration when it's no longer needed.
HTTP method and endpoint
DELETE /protocols/san/portsets/{uuid}
Introduced in
ONTAP 9.9
Related ONTAP commands
lun portset delete
Learn more
uuid |
string |
path |
True |
The unique identifier of the portset. |
allow_delete_while_bound |
boolean |
query |
False |
Allows deletion of a portset that is bound to an igroup. Deleting a portset can expand the set of LIFs through which a LUN is available.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374063 |
An attempt was made to delete a portset that is bound to an initiator group without using query parameter |
5374908 |
The portset does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
