Create a legal-hold end on all of the files for a litigation ID
Ends a legal hold on all files associated with a specified litigation ID when no operation is in progress. Use this to conclude legal holds in compliance with your data governance needs.
HTTP method and endpoint
DELETE /storage/snaplock/litigations/{id}
Introduced in
ONTAP 9.7
Usage notes
Creates a legal-hold end on all of the files for the specified litigation ID. This is only allowed when an operation is no longer in progress.
Related ONTAP commands
snaplock legal-hold end
Example
DELETE "/api/storage/snaplock/litigations/fd72e138-4bc3-11e9-a85f-0050568eb48f%3Al3"
Learn more
id |
string |
path |
True |
Litigation ID |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
13763280 |
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation. |
14090343 |
Invalid Field |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090642 |
Legal-Hold operation is in progress. Legal-Hold end cannot be performed. Wait for the operation to complete or abort the operation |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
