Retrieve an application template
Retrieves an application template to examine its properties and prerequisites, which are specific to each template. Use this endpoint to ensure that all necessary prerequisites are met before utilizing the template in your applications.
HTTP method and endpoint
GET /application/templates/{name}
Introduced in
ONTAP 9.6
Template properties
Each application template has a set of properties. These properties are always nested under a property with the same name as the template. For example, when using the mongo_db_on_san template, the properties are found nested inside the mongo_db_on_san property. The properties nested under the template property are all specific to the template. The model for the application template object includes all the available templates, but only the object that corresponds to the template's name is returned, and only one is provided in any application API.
The model of each template includes a description of each property and its allowed values or usage. Default values are also indicated when available. The template properties returned by this API include an example value for each property.
Template prerequisites
Each template has a set of prerequisites required for its use. If any of these prerequisites are not met, the missing_prerequisites property indicates which prerequisite is missing.
Learn more
name |
string |
path |
True |
Template Name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
description |
string |
Description. |
missing_prerequisites |
string |
Missing prerequisites. |
mongo_db_on_san |
MongoDB using SAN. |
name |
string |
Template name. |
nas |
A generic NAS application. |
nvme |
An NVME application. |
oracle_on_nfs |
Oracle using NFS. |
oracle_on_san |
Oracle using SAN. |
oracle_rac_on_nfs |
Oracle RAC using NFS. |
oracle_rac_on_san |
Oracle RAC using SAN. |
protocol |
string |
Access protocol. |
s3_bucket |
A generic S3 bucket application. |
san |
A generic SAN application. |
sql_on_san |
Microsoft SQL using SAN. |
sql_on_smb |
Microsoft SQL using SMB. |
vdi_on_nas |
A VDI application using NAS. |
vdi_on_san |
A VDI application using SAN. |
vsi_on_nas |
A VSI application using NAS. |
vsi_on_san |
A VSI application using SAN. |
"href": "/api/resourcelink"
"description": "string",
"missing_prerequisites": "string",
"mongo_db_on_san": {
"dataset": {
"size": 0,
"storage_service": {
"name": "string"
"os_type": "string",
"primary_igroup_name": "string",
"protection_type": {
"local_rpo": "string",
"remote_rpo": "string"
"secondary_igroups": [
"name": "string"
"name": "string",
"nas": {
"application_components": [
"export_policy": {
"name": "string"
"flexcache": {
"origin": {
"component": {
"name": "string"
"svm": {
"name": "string"
"name": "string",
"qos": {
"policy": {
"name": "string",
"uuid": "string"
"share_count": 0,
"snaplock": {
"autocommit_period": "string",
"retention": {
"default": "string",
"maximum": "string",
"minimum": "string"
"snaplock_type": "string"
"name": "string"
"tiering": {
"policy": "string"
"total_size": 0
"cifs_access": [
"access": "string",
"user_or_group": "string"
"cifs_share_name": "string",
"exclude_aggregates": [
"name": "string",
"uuid": "string"
"nfs_access": [
"access": "string",
"host": "string"
"local_policy": "string",
"nvme": {
"components": [
"name": "string",
"performance": {
"name": "string"
"qos": {
"policy": {
"name": "string",
"uuid": "string"
"subsystem": {
"hosts": [
"dh_hmac_chap": {
"group_size": "string",
"hash_function": "string"
"nqn": "string",
"priority": "string"
"name": "string",
"uuid": "string"
"tiering": {
"policy": "string"
"rpo": {
"local": {
"name": "string",
"policy": "string"
"remote": {
"name": "string"
"oracle_on_nfs": {
"archive_log": {
"name": "string"
"db": {
"size": 0,
"name": "string"
"nfs_access": [
"access": "string",
"host": "string"
"ora_home": {
"name": "string"
"redo_log": {
"size": 0,
"name": "string"
"oracle_on_san": {
"archive_log": {
"name": "string"
"db": {
"size": 0,
"name": "string"
"igroup_name": "string",
"ora_home": {
"name": "string"
"redo_log": {
"size": 0,
"name": "string"
"oracle_rac_on_nfs": {
"archive_log": {
"name": "string"
"db": {
"size": 0,
"name": "string"
"grid_binary": {
"name": "string"
"nfs_access": [
"access": "string",
"host": "string"
"ora_home": {
"name": "string"
"oracle_crs": {
"name": "string"
"redo_log": {
"size": 0,
"name": "string"
"oracle_rac_on_san": {
"archive_log": {
"name": "string"
"db": {
"size": 0,
"name": "string"
"db_sids": [
"grid_binary": {
"name": "string"
"ora_home": {
"name": "string"
"oracle_crs": {
"name": "string"
"redo_log": {
"size": 0,
"name": "string"
"protocol": "string",
"s3_bucket": {
"access_policies": [
"actions": [
"string"
"conditions": [
"delimiters": [
"string"
"max_keys": [
"integer"
"operator": "string",
"prefixes": [
"string"
"source_ips": [
"string"
"usernames": [
"string"
"effect": "string",
"principals": [
"string"
"resources": [
"string"
"sid": "string"
"bucket_endpoint_type": "string",
"comment": "string",
"default_retention_period": "string",
"name": "string",
"uuid": "string"
"name": "string",
"nas_path": "string",
"qos": {
"policy": {
"name": "string",
"uuid": "string"
"retention_mode": "string",
"name": "string"
"uuid": "string",
"versioning_state": "string"
"san": {
"name": "string",
"qos": {
"policy": {
"name": "string",
"uuid": "string"
"name": "string"
"tiering": {
"policy": "string"
"name": "string",
"uuid": "string"
"sql_on_san": {
"db": {
"size": 0,
"name": "string"
"log": {
"size": 0,
"name": "string"
"temp_db": {
"name": "string"
"sql_on_smb": {
"access": {
"installer": "string",
"service_account": "string"
"db": {
"size": 0,
"name": "string"
"log": {
"size": 0,
"name": "string"
"temp_db": {
"name": "string"
"vdi_on_nas": {
"desktops": {
"size": 0,
"name": "string"
"hyper_v_access": {
"nfs_access": [
"access": "string",
"host": "string"
"vdi_on_san": {
"desktops": {
"size": 0,
"name": "string"
"hypervisor": "string",
"vsi_on_nas": {
"datastore": {
"size": 0,
"name": "string"
"hyper_v_access": {
"nfs_access": [
"access": "string",
"host": "string"
"vsi_on_san": {
"datastore": {
"size": 0,
"name": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
storage_service
name |
string |
The storage service of the database. |
dataset
element_count |
integer |
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range. |
replication_factor |
integer |
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary. |
size |
integer |
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
igroups
initiator_objects
mongo_db_on_san_new_igroups
The list of initiator groups to create.
initiators |
array[string] |
protection_type
local_rpo |
string |
The local RPO of the application. |
remote_rpo |
string |
The remote RPO of the application. |
secondary_igroups
name |
string |
The name of the initiator group for each secondary. |
mongo_db_on_san
MongoDB using SAN.
dataset |
os_type |
string |
The name of the host OS running the application. |
primary_igroup_name |
string |
The initiator group for the primary. |
protection_type |
secondary_igroups |
array[secondary_igroups] |
export_policy
id |
integer |
The ID of an existing NFS export policy. |
name |
string |
The name of an existing NFS export policy. |
component
name |
string |
Name of the source component. |
svm
name |
string |
Name of the source SVM. |
origin
component |
svm |
flexcache
dr_cache |
boolean |
Dr-cache is a FlexCache volume create time option that has the same flexgroup-msid as that of the origin of a FlexCache volume. By default, dr-cache is disabled. The flexgroup-msid of the FlexCache volume does not need to be same as that of the origin of a FlexCache volume. |
origin |
policy
name |
string |
The name of an existing QoS policy. |
uuid |
string |
The UUID of an existing QoS policy. Usage: <UUID> |
qos
policy |
retention
default |
string |
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as quot;Plt;num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period and the string "unspecified" to set an unspecified retention period. |
maximum |
string |
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P<num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period. |
minimum |
string |
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "P<num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period. |
snaplock
append_mode_enabled |
boolean |
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires. |
autocommit_period |
string |
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P<num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the autocommit field also accepts the string "none". |
retention |
snaplock_type |
string |
The SnapLock type of the smart container. |
storage_service
name |
string |
The storage service of the application component. |
object_stores
nas_application_components_tiering
application-components.tiering
policy |
string |
The storage tiering type of the application component. |
export_policy |
flexcache |
name |
string |
The name of the application component. |
qos |
scale_out |
boolean |
Denotes a Flexgroup. |
share_count |
integer |
The number of shares in the application component. |
snaplock |
snapshot_locking_enabled |
boolean |
Indicates whether Snapshot copy locking is enabled on the volume. |
storage_service |
tiering |
application-components.tiering |
total_size |
integer |
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]} |
app_cifs_access
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access.
access |
string |
The CIFS access granted to the user or group. |
user_or_group |
string |
The name of the CIFS user or group that will be granted access. |
exclude_aggregates
name |
string |
The name of the aggregate to exclude. Usage: <aggregate name> |
uuid |
string |
The ID of the aggregate to exclude. Usage: <UUID> |
app_nfs_access
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access.
access |
string |
The NFS access granted. |
host |
string |
The name of the NFS entity granted access. |
protection_type
local_policy |
string |
The Snapshot copy policy to apply to each volume in the smart container. This property is only supported for smart containers. Usage: <snapshot policy> |
local_rpo |
string |
remote_rpo |
string |
nas
application_components |
array[application_components] |
cifs_access |
array[app_cifs_access] |
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access. |
cifs_share_name |
string |
The name of the CIFS share. Usage: <Share> |
exclude_aggregates |
array[exclude_aggregates] |
nfs_access |
array[app_nfs_access] |
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access. |
protection_type |
performance
storage_service |
dh_hmac_chap
group_size |
string |
Authentication Diffie-Hellman Group. |
hash_function |
string |
Authentication Hash Function. |
hosts
dh_hmac_chap |
nqn |
string |
The host NQN. |
priority |
string |
Host Priority. |
zapp_nvme_components_subsystem
components.subsystem
hosts |
array[hosts] |
name |
string |
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not. |
os_type |
string |
The name of the host OS accessing the component. The default value is the host OS that is running the application. |
uuid |
string |
The UUID of an existing subsystem to be granted access to the component. |
zapp_nvme_components_tiering
policy |
string |
components
name |
string |
namespace_count |
integer |
The number of namespaces supported per request, with a total limit of 1024 per volume. |
os_type |
string |
performance |
qos |
subsystem |
components.subsystem |
tiering |
total_size |
integer |
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]} |
local
name |
string |
policy |
string |
remote
name |
string |
rpo
local |
remote |
zapp_nvme
components |
array[components] |
os_type |
string |
rpo |
storage_service
name |
string |
The storage service of the archive log. |
archive_log
size |
integer |
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
db
size |
integer |
storage_service |
storage_service
name |
string |
The storage service of the ORACLE_HOME storage volume. |
ora_home
size |
integer |
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the redo log group. |
redo_log
mirrored |
boolean |
Specifies whether the redo log group should be mirrored. |
size |
integer |
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_on_nfs
Oracle using NFS.
archive_log |
db |
nfs_access |
ora_home |
protection_type |
redo_log |
oracle_on_san_new_igroups
initiators |
array[string] |
oracle_on_san
Oracle using SAN.
archive_log |
db |
igroup_name |
string |
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup. |
ora_home |
os_type |
string |
protection_type |
redo_log |
storage_service
name |
string |
The storage service of the Oracle grid binary storage volume. |
grid_binary
size |
integer |
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the Oracle CRS volume. |
oracle_crs
copies |
integer |
The number of CRS volumes. |
size |
integer |
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_rac_on_nfs
archive_log |
db |
grid_binary |
nfs_access |
ora_home |
oracle_crs |
protection_type |
redo_log |
db_sids
igroup_name |
string |
oracle_rac_on_san_new_igroups
initiators |
array[string] |
oracle_rac_on_san
archive_log |
db |
db_sids |
array[db_sids] |
grid_binary |
ora_home |
oracle_crs |
os_type |
string |
protection_type |
redo_log |
zapp_s3_bucket_application_components_access_policies_conditions
conditions
delimiters |
array[string] |
max_keys |
array[integer] |
operator |
string |
Policy Condition Operator. |
prefixes |
array[string] |
source_ips |
array[string] |
usernames |
array[string] |
The list of S3 objectstore policies to be created.
actions |
array[string] |
conditions |
array[zapp_s3_bucket_application_components_access_policies_conditions] |
conditions. |
effect |
string |
Allow or Deny Access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Statement Identifier Usage: <(size 1..256)> |
The list of application components to be created.
access_policies |
array[zapp_s3_bucket_application_components_access_policies] |
The list of S3 objectstore policies to be created. |
bucket_endpoint_type |
string |
The type of bucket. |
capacity_tier |
boolean |
Prefer lower latency storage under similar media costs. |
comment |
string |
Object Store Server Bucket Description Usage: <(size 1..256)> |
default_retention_period |
string |
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as quot;Plt;num>Y" and quot;Plt;num>D" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported. Usage: {{<integer> days|years} | none} |
name |
string |
nas_path |
string |
The path to which the bucket corresponds to. |
qos |
retention_mode |
string |
The lock mode of the bucket. <br>compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. <br> governance ‐ An administrator can delete a Governance bucket.<br> no_lock ‐ Indicates the bucket does not support object locking. For s3 type buckets, the default value is no_lock. |
size |
integer |
The total size of the S3 Bucket, split across the member components. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
uuid |
string |
Object Store Server Bucket UUID Usage: <UUID> |
versioning_state |
string |
Bucket Versioning State. For nas type buckets, this field is not set. For s3 type buckets, the default value is disabled. |
protection_type
remote_rpo |
string |
zapp_s3_bucket
The list of application components to be created. |
protection_type |
san_application_components_tiering
policy |
string |
igroup_name |
string |
lun_count |
integer |
The number of LUNs in the application component. |
name |
string |
os_type |
string |
qos |
storage_service |
tiering |
total_size |
integer |
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]} |
san_new_igroups
initiators |
array[string] |
san
os_type |
string |
protection_type |
storage_service
name |
string |
The storage service of the DB. |
db
size |
integer |
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the log DB. |
log
size |
integer |
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san_new_igroups
initiators |
array[string] |
storage_service
name |
string |
The storage service of the temp DB. |
temp_db
size |
integer |
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san
db |
igroup_name |
string |
log |
os_type |
string |
protection_type |
server_cores_count |
integer |
The number of server cores for the DB. |
temp_db |
access
installer |
string |
SQL installer admin user name. |
service_account |
string |
SQL service account user name. |
sql_on_smb
access |
db |
log |
protection_type |
integer |
temp_db |
storage_service
name |
string |
The storage service of the desktops. |
desktops
count |
integer |
The number of desktops to support. |
size |
integer |
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
hyper_v_access
service_account |
string |
Hyper-V service account. |
vdi_on_nas
desktops |
hyper_v_access |
nfs_access |
protection_type |
vdi_on_san_new_igroups
initiators |
array[string] |
vdi_on_san
desktops |
hypervisor |
string |
The name of the hypervisor hosting the application. |
igroup_name |
string |
protection_type |
storage_service
name |
string |
The storage service of the datastore. |
datastore
count |
integer |
The number of datastores to support. |
size |
integer |
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
vsi_on_nas
datastore |
hyper_v_access |
nfs_access |
protection_type |
vsi_on_san_new_igroups
initiators |
array[string] |
vsi_on_san
datastore |
hypervisor |
string |
igroup_name |
string |
protection_type |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
