REST API reference
Retrieve an application template
Retrieves an application template to access its properties and prerequisites. This information helps you configure applications according to the available templates in your environment.
HTTP method and endpoint
GET /application/templates/{name}
Introduced in
ONTAP 9.6
Template properties
Each application template has a set of properties. These properties are always nested under a property with the same name as the template. For example, when using the mongo_db_on_san template, the properties are found nested inside the mongo_db_on_san property. The properties nested under the template property are all specific to the template. The model for the application template object includes all the available templates, but only the object that corresponds to the template's name is returned, and only one is provided in any application API.
The model of each template includes a description of each property and its allowed values or usage. Default values are also indicated when available. The template properties returned by this API include an example value for each property.
Template prerequisites
Each template has a set of prerequisites required for its use. If any of these prerequisites are not met, the missing_prerequisites property indicates which prerequisite is missing.
Learn more
name
string
path
True
Template Name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
description
string
Description.
string
Missing prerequisites.
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
name
string
Template name.
nas
nas
A generic NAS application.
nvme
zapp_nvme
An NVME application.
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
Oracle RAC using NFS.
oracle_rac_on_san
oracle_rac_on_san
Oracle RAC using SAN.
protocol
string
Access protocol.
s3_bucket
zapp_s3_bucket
A generic S3 bucket application.
san
san
A generic SAN application.
sql_on_san
sql_on_san
Microsoft SQL using SAN.
sql_on_smb
sql_on_smb
Microsoft SQL using SMB.
vdi_on_nas
vdi_on_nas
A VDI application using NAS.
vdi_on_san
vdi_on_san
A VDI application using SAN.
vsi_on_nas
vsi_on_nas
A VSI application using NAS.
vsi_on_san
vsi_on_san
A VSI application using SAN.
      "href": "/api/resourcelink"
  "description": "string",
  "missing_prerequisites": "string",
  "mongo_db_on_san": {
    "dataset": {
      "size": 0,
      "storage_service": {
        "name": "string"
    "os_type": "string",
    "primary_igroup_name": "string",
    "protection_type": {
      "local_rpo": "string",
      "remote_rpo": "string"
    "secondary_igroups": [
        "name": "string"
  "name": "string",
  "nas": {
    "application_components": [
        "export_policy": {
          "name": "string"
        "flexcache": {
          "origin": {
            "component": {
              "name": "string"
            "svm": {
              "name": "string"
        "name": "string",
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
        "share_count": 0,
        "snaplock": {
          "autocommit_period": "string",
          "retention": {
            "default": "string",
            "maximum": "string",
            "minimum": "string"
          "snaplock_type": "string"
          "name": "string"
        "tiering": {
          "policy": "string"
        "total_size": 0
    "cifs_access": [
        "access": "string",
        "user_or_group": "string"
    "cifs_share_name": "string",
    "exclude_aggregates": [
        "name": "string",
        "uuid": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
      "local_policy": "string",
  "nvme": {
    "components": [
        "name": "string",
        "performance": {
            "name": "string"
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
        "subsystem": {
          "hosts": [
              "dh_hmac_chap": {
                "group_size": "string",
                "hash_function": "string"
              "nqn": "string",
              "priority": "string"
          "name": "string",
          "uuid": "string"
        "tiering": {
          "policy": "string"
    "rpo": {
      "local": {
        "name": "string",
        "policy": "string"
      "remote": {
        "name": "string"
  "oracle_on_nfs": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
    "ora_home": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "oracle_on_san": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "igroup_name": "string",
    "ora_home": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "oracle_rac_on_nfs": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "grid_binary": {
        "name": "string"
    "nfs_access": [
        "access": "string",
        "host": "string"
    "ora_home": {
        "name": "string"
    "oracle_crs": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "oracle_rac_on_san": {
    "archive_log": {
        "name": "string"
    "db": {
      "size": 0,
        "name": "string"
    "db_sids": [
    "grid_binary": {
        "name": "string"
    "ora_home": {
        "name": "string"
    "oracle_crs": {
        "name": "string"
    "redo_log": {
      "size": 0,
        "name": "string"
  "protocol": "string",
  "s3_bucket": {
        "access_policies": [
            "actions": [
              "string"
            "conditions": [
                "delimiters": [
                  "string"
                "max_keys": [
                  "integer"
                "operator": "string",
                "prefixes": [
                  "string"
                "source_ips": [
                  "string"
                "usernames": [
                  "string"
            "effect": "string",
            "principals": [
              "string"
            "resources": [
              "string"
            "sid": "string"
        "bucket_endpoint_type": "string",
        "comment": "string",
        "default_retention_period": "string",
            "name": "string",
            "uuid": "string"
        "name": "string",
        "nas_path": "string",
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
        "retention_mode": "string",
          "name": "string"
        "uuid": "string",
        "versioning_state": "string"
  "san": {
        "name": "string",
        "qos": {
          "policy": {
            "name": "string",
            "uuid": "string"
          "name": "string"
        "tiering": {
          "policy": "string"
        "name": "string",
        "uuid": "string"
  "sql_on_san": {
    "db": {
      "size": 0,
        "name": "string"
    "log": {
      "size": 0,
        "name": "string"
    "temp_db": {
        "name": "string"
  "sql_on_smb": {
    "access": {
      "installer": "string",
      "service_account": "string"
    "db": {
      "size": 0,
        "name": "string"
    "log": {
      "size": 0,
        "name": "string"
    "temp_db": {
        "name": "string"
  "vdi_on_nas": {
    "desktops": {
      "size": 0,
        "name": "string"
    "hyper_v_access": {
    "nfs_access": [
        "access": "string",
        "host": "string"
  "vdi_on_san": {
    "desktops": {
      "size": 0,
        "name": "string"
    "hypervisor": "string",
  "vsi_on_nas": {
    "datastore": {
      "size": 0,
        "name": "string"
    "hyper_v_access": {
    "nfs_access": [
        "access": "string",
        "host": "string"
  "vsi_on_san": {
    "datastore": {
      "size": 0,
        "name": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
storage_service
name
string
The storage service of the database.
dataset
element_count
integer
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range.
replication_factor
integer
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary.
size
integer
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
igroups
initiator_objects
mongo_db_on_san_new_igroups
The list of initiator groups to create.
initiators
array[string]
protection_type
local_rpo
string
The local RPO of the application.
remote_rpo
string
The remote RPO of the application.
secondary_igroups
name
string
The name of the initiator group for each secondary.
mongo_db_on_san
MongoDB using SAN.
dataset
dataset
os_type
string
The name of the host OS running the application.
primary_igroup_name
string
The initiator group for the primary.
protection_type
protection_type
secondary_igroups
array[secondary_igroups]
export_policy
id
integer
The ID of an existing NFS export policy.
name
string
The name of an existing NFS export policy.
component
name
string
Name of the source component.
svm
name
string
Name of the source SVM.
origin
component
component
svm
svm
flexcache
dr_cache
boolean
Dr-cache is a FlexCache volume create time option that has the same flexgroup-msid as that of the origin of a FlexCache volume. By default, dr-cache is disabled. The flexgroup-msid of the FlexCache volume does not need to be same as that of the origin of a FlexCache volume.
origin
origin
policy
name
string
The name of an existing QoS policy.
uuid
string
The UUID of an existing QoS policy. Usage: <UUID>
qos
policy
policy
retention
default
string
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as quot;Plt;num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period and the string "unspecified" to set an unspecified retention period.
maximum
string
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P<num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
minimum
string
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "P<num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
snaplock
append_mode_enabled
boolean
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires.
autocommit_period
string
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P<num>Y", "P<num>M", "P<num>D" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PT<num>H" and "PT<num>M" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the autocommit field also accepts the string "none".
retention
retention
snaplock_type
string
The SnapLock type of the smart container.
storage_service
name
string
The storage service of the application component.
object_stores
nas_application_components_tiering
application-components.tiering
policy
string
The storage tiering type of the application component.
export_policy
export_policy
flexcache
flexcache
name
string
The name of the application component.
qos
qos
scale_out
boolean
Denotes a Flexgroup.
share_count
integer
The number of shares in the application component.
snaplock
snaplock
snapshot_locking_enabled
boolean
Indicates whether Snapshot copy locking is enabled on the volume.
storage_service
storage_service
tiering
total_size
integer
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]}
app_cifs_access
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access.
access
string
The CIFS access granted to the user or group.
user_or_group
string
The name of the CIFS user or group that will be granted access.
exclude_aggregates
name
string
The name of the aggregate to exclude. Usage: <aggregate name>
uuid
string
The ID of the aggregate to exclude. Usage: <UUID>
app_nfs_access
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access.
access
string
The NFS access granted.
host
string
The name of the NFS entity granted access.
protection_type
local_policy
string
The Snapshot copy policy to apply to each volume in the smart container. This property is only supported for smart containers. Usage: <snapshot policy>
local_rpo
string
remote_rpo
string
nas
array[application_components]
cifs_access
array[app_cifs_access]
cifs_share_name
string
The name of the CIFS share. Usage: <Share>
exclude_aggregates
array[exclude_aggregates]
nfs_access
array[app_nfs_access]
protection_type
protection_type
performance
storage_service
storage_service
dh_hmac_chap
group_size
string
Authentication Diffie-Hellman Group.
hash_function
string
Authentication Hash Function.
hosts
dh_hmac_chap
dh_hmac_chap
nqn
string
The host NQN.
priority
string
Host Priority.
zapp_nvme_components_subsystem
components.subsystem
hosts
array[hosts]
name
string
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not.
os_type
string
The name of the host OS accessing the component. The default value is the host OS that is running the application.
uuid
string
The UUID of an existing subsystem to be granted access to the component.
zapp_nvme_components_tiering
policy
string
components
name
string
namespace_count
integer
The number of namespaces supported per request, with a total limit of 1024 per volume.
os_type
string
performance
performance
qos
qos
subsystem
tiering
total_size
integer
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]}
local
name
string
policy
string
remote
name
string
rpo
local
local
remote
remote
zapp_nvme
components
array[components]
os_type
string
rpo
rpo
storage_service
name
string
The storage service of the archive log.
archive_log
size
integer
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
db
size
integer
storage_service
storage_service
storage_service
name
string
The storage service of the ORACLE_HOME storage volume.
ora_home
size
integer
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the redo log group.
redo_log
mirrored
boolean
Specifies whether the redo log group should be mirrored.
size
integer
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_on_nfs
Oracle using NFS.
archive_log
archive_log
db
db
nfs_access
ora_home
ora_home
protection_type
protection_type
redo_log
redo_log
oracle_on_san_new_igroups
initiators
array[string]
oracle_on_san
Oracle using SAN.
archive_log
archive_log
db
db
igroup_name
string
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup.
ora_home
ora_home
os_type
string
protection_type
protection_type
redo_log
redo_log
storage_service
name
string
The storage service of the Oracle grid binary storage volume.
grid_binary
size
integer
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the Oracle CRS volume.
oracle_crs
copies
integer
The number of CRS volumes.
size
integer
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_rac_on_nfs
archive_log
archive_log
db
db
grid_binary
grid_binary
nfs_access
ora_home
ora_home
oracle_crs
oracle_crs
protection_type
protection_type
redo_log
redo_log
db_sids
igroup_name
string
oracle_rac_on_san_new_igroups
initiators
array[string]
oracle_rac_on_san
archive_log
archive_log
db
db
db_sids
array[db_sids]
grid_binary
grid_binary
ora_home
ora_home
oracle_crs
oracle_crs
os_type
string
protection_type
protection_type
redo_log
redo_log
zapp_s3_bucket_application_components_access_policies_conditions
conditions
delimiters
array[string]
max_keys
array[integer]
operator
string
Policy Condition Operator.
prefixes
array[string]
source_ips
array[string]
usernames
array[string]
The list of S3 objectstore policies to be created.
actions
array[string]
conditions
array[zapp_s3_bucket_application_components_access_policies_conditions]
conditions.
effect
string
Allow or Deny Access.
principals
array[string]
resources
array[string]
sid
string
Statement Identifier Usage: <(size 1..256)>
The list of application components to be created.
access_policies
array[zapp_s3_bucket_application_components_access_policies]
string
The type of bucket.
capacity_tier
boolean
Prefer lower latency storage under similar media costs.
comment
string
Object Store Server Bucket Description Usage: <(size 1..256)>
string
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as quot;Plt;num>Y" and quot;Plt;num>D" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported. Usage: {{<integer> days|years} | none}
exclude_aggregates
name
string
nas_path
string
The path to which the bucket corresponds to.
qos
qos
retention_mode
string
The lock mode of the bucket. <br>compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. <br> governance ‐ An administrator can delete a Governance bucket.<br> no_lock ‐ Indicates the bucket does not support object locking. For s3 type buckets, the default value is no_lock.
size
integer
The total size of the S3 Bucket, split across the member components. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
uuid
string
Object Store Server Bucket UUID Usage: <UUID>
versioning_state
string
Bucket Versioning State. For nas type buckets, this field is not set. For s3 type buckets, the default value is disabled.
protection_type
remote_rpo
string
zapp_s3_bucket
array[zapp_s3_bucket_application_components]
protection_type
protection_type
san_application_components_tiering
policy
string
igroup_name
string
lun_count
integer
The number of LUNs in the application component.
name
string
os_type
string
qos
qos
storage_service
storage_service
tiering
total_size
integer
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]}
san_new_igroups
initiators
array[string]
san
exclude_aggregates
os_type
string
protection_type
protection_type
storage_service
name
string
The storage service of the DB.
db
size
integer
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the log DB.
log
size
integer
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san_new_igroups
initiators
array[string]
storage_service
name
string
The storage service of the temp DB.
temp_db
size
integer
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san
db
db
igroup_name
string
log
log
os_type
string
protection_type
protection_type
server_cores_count
integer
The number of server cores for the DB.
temp_db
temp_db
access
installer
string
SQL installer admin user name.
service_account
string
SQL service account user name.
sql_on_smb
access
access
db
db
log
log
protection_type
protection_type
server_cores_count
integer
temp_db
temp_db
storage_service
name
string
The storage service of the desktops.
desktops
count
integer
The number of desktops to support.
size
integer
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
hyper_v_access
service_account
string
Hyper-V service account.
vdi_on_nas
desktops
desktops
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vdi_on_san_new_igroups
initiators
array[string]
vdi_on_san
desktops
desktops
hypervisor
string
The name of the hypervisor hosting the application.
igroup_name
string
protection_type
protection_type
storage_service
name
string
The storage service of the datastore.
datastore
count
integer
The number of datastores to support.
size
integer
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
vsi_on_nas
datastore
datastore
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vsi_on_san_new_igroups
initiators
array[string]
vsi_on_san
datastore
datastore
hypervisor
string
igroup_name
string
protection_type
protection_type
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
