REST API reference
Retrieve a collection of chassis
Accesses information about multiple chassis, which helps you manage and organize your hardware resources effectively.
HTTP method and endpoint
GET /cluster/chassis
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of chassis.
  • system chassis show
  • system chassis fru show
state
string
query
False
Filter by state
nodes.name
string
query
False
Filter by nodes.name
nodes.pcis.cards.slot
string
query
False
Filter by nodes.pcis.cards.slot
  • Introduced in: 9.9
nodes.pcis.cards.device
string
query
False
Filter by nodes.pcis.cards.device
nodes.pcis.cards.info
string
query
False
Filter by nodes.pcis.cards.info
nodes.position
string
query
False
Filter by nodes.position
  • Introduced in: 9.8
nodes.uuid
string
query
False
Filter by nodes.uuid
nodes.usbs.supported
boolean
query
False
Filter by nodes.usbs.supported
nodes.usbs.ports.connected
boolean
query
False
Filter by nodes.usbs.ports.connected
nodes.usbs.enabled
boolean
query
False
Filter by nodes.usbs.enabled
shelves.uid
string
query
False
Filter by shelves.uid
frus.id
string
query
False
Filter by frus.id
frus.state
string
query
False
Filter by frus.state
frus.type
string
query
False
Filter by frus.type
id
string
query
False
Filter by id
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[chassis]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "frus": [
          "id": "string",
          "state": "string",
          "type": "string"
      "id": "021352005981",
      "nodes": [
          "name": "node1",
          "pcis": {
            "cards": [
                "device": "Intel Lewisburg series chipset SATA Controller",
                "info": "Additional Info: 0 (0xaaf00000)   SHM2S86Q120GLM22NP FW1146 114473MB 512B/sect (SPG190108GW)",
                "slot": "0"
          "position": "top",
          "usbs": {
            "ports": [
      "shelves": [
          "uid": "7777841915827391056"
      "state": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
frus
id
string
state
string
type
string
self
cards
device
string
The description of the PCI card.
info
string
The info string from the device driver of the PCI card.
slot
string
The slot where the PCI card is placed. This can sometimes take the form of "6-1" to indicate slot and subslot.
pcis
cards
array[cards]
ports
connected
boolean
Indicates whether or not the USB port has a device connected to it.
usbs
The status of the USB ports on the controller.
enabled
boolean
Indicates whether or not the USB ports are enabled.
ports
array[ports]
supported
boolean
Indicates whether or not USB ports are supported on the current platform.
nodes
List of nodes in chassis.
_links
_links
name
string
pcis
pcis
position
string
The position of the node in the chassis, when viewed from the rear of the system.
usbs
usbs
uuid
string
shelf_reference
Shelf
_links
_links
uid
string
chassis
frus
array[frus]
List of FRUs in the chassis.
id
string
nodes
array[nodes]
List of nodes in the chassis.
shelves
array[shelf_reference]
List of shelves in chassis.
state
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
