Retrieve a collection of chassis
GET /cluster/chassis
Retrieves a collection of chassis.
Related ONTAP commands
system chassis show -
system chassis fru show
Learn more
frus.type |
string |
query |
False |
Filter by frus.type |
frus.state |
string |
query |
False |
Filter by frus.state |
frus.id |
string |
query |
False |
Filter by frus.id |
nodes.name |
string |
query |
False |
Filter by nodes.name |
nodes.uuid |
string |
query |
False |
Filter by nodes.uuid |
state |
string |
query |
False |
Filter by state |
shelves.uid |
string |
query |
False |
Filter by shelves.uid |
id |
string |
query |
False |
Filter by id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[chassis] |
"next": {
"href": "/api/resourcelink"
"records": [
"frus": [
"id": "string",
"state": "string",
"type": "string"
"id": "021352005981",
"nodes": [
"name": "node1",
"shelves": [
"uid": 7777841915827391056
"state": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
frus
id |
string |
state |
string |
type |
string |
_links
self |
nodes
_links |
name |
string |
uuid |
string |
shelf_reference
Shelf
_links |
uid |
string |
chassis
frus |
array[frus] |
List of frus in chassis |
id |
string |
nodes |
array[nodes] |
List of nodes in chassis |
shelves |
array[shelf_reference] |
List of shelves in chassis |
state |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
