Retrieve license managers
Retrieves a list of license managers, accessing information about license management across your systems.
HTTP method and endpoint
GET /cluster/licensing/license-managers
Introduced in
ONTAP 9.8
Usage notes
Retrieves a collection of license managers.
Learn more
Related ONTAP commands
system license license-manager show
uuid |
string |
query |
False |
Filter by uuid |
default |
boolean |
query |
False |
Filter by default |
uri.host |
string |
query |
False |
Filter by uri.host |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"uri": {
"host": "10.1.1.1"
"uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
uri
License manager URI.
host |
string |
License manager host name, IPv4 or IPv6 address. |
records
Information on a license manager instance associated with the cluster.
_links |
default |
boolean |
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance. |
uri |
License manager URI. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
