REST API reference
Retrieve license managers
GET /cluster/licensing/license-managers
Introduced In: 9.8
Retrieves a collection of license managers.
  • system license license-manager show
uri.host
string
query
False
Filter by uri.host
uuid
string
query
False
Filter by uuid
default
boolean
query
False
Filter by default
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "uri": {
        "host": "10.1.1.1"
      "uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
uri
License manager URI.
host
string
License manager host name, IPv4 or IPv6 address.
records
Information on a license manager instance associated with the cluster.
_links
self_link
default
boolean
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance.
uri
uri
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
