Retrieve FC interfaces
Retrieves information about Fibre Channel (FC) interfaces to understand their configuration and status within your network setup. Accessing this data helps in monitoring and managing FC connections effectively.
HTTP method and endpoint
GET /network/fc/interfaces
Introduced in
ONTAP 9.6
Usage notes
Retrieves FC interfaces.
Related ONTAP commands
network interface show -
vserver fcp interface show
Learn more
recommend.svm.name |
string |
query |
False |
The name of an existing SVM for which to recommend FC interfaces. If neither query parameter
recommend.svm.uuid |
string |
query |
False |
The UUID of an existing SVM for which to recommend FC interfaces. If neither query parameter
recommend.data_protocol |
string |
query |
False |
The target data protocol for which to recommend FC interfaces. This query parameter is required when recommending FC interfaces.
recommend.interfaces_per_node |
integer |
query |
False |
The target number of interfaces per FC fabric per cluster node when recommending FC interfaces. If this query parameter is not provided, the default value is one (1).
recommend.fabrics.name |
array[string] |
query |
False |
The names of the FC fabrics to target when recommending FC interfaces. If this query parameter is not provided, FC interfaces will be recommended for each FC fabric discovered.
recommend.nodes.name |
array[string] |
query |
False |
The names of the cluster nodes to target when recommending FC interfaces. If this query parameter is not provided, FC interfaces will be recommended for all nodes that have FC network ports supporting target data protocol. Query parameters
recommend.nodes.uuid |
array[string] |
query |
False |
The UUIDs of the cluster nodes to target when recommending FC interfaces. If this query parameter is not provided, FC interfaces will be recommended for all nodes that have FC network ports supporting target data protocol. Query parameters
recommend.proposed.locations.port.uuid |
array[string] |
query |
False |
The UUIDs of the FC ports on which FC interfaces are proposed. A UUID may be supplied multiple times to proposed multiple FC interfaces. FC ports must be enabled, support the target data protocol and be reporting an FC fabric.
enabled |
boolean |
query |
False |
Filter by enabled |
location.is_home |
boolean |
query |
False |
Filter by location.is_home
location.port.uuid |
string |
query |
False |
Filter by location.port.uuid |
location.port.name |
string |
query |
False |
Filter by location.port.name |
location.port.node.name |
string |
query |
False |
Filter by location.port.node.name |
location.home_node.name |
string |
query |
False |
Filter by location.home_node.name
location.home_node.uuid |
string |
query |
False |
Filter by location.home_node.uuid
location.home_port.uuid |
string |
query |
False |
Filter by location.home_port.uuid
location.home_port.name |
string |
query |
False |
Filter by location.home_port.name
location.home_port.node.name |
string |
query |
False |
Filter by location.home_port.node.name
location.node.name |
string |
query |
False |
Filter by location.node.name |
location.node.uuid |
string |
query |
False |
Filter by location.node.uuid |
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.iops.total |
integer |
query |
False |
Filter by metric.iops.total
metric.iops.other |
integer |
query |
False |
Filter by metric.iops.other
metric.iops.write |
integer |
query |
False |
Filter by metric.iops.write
metric.iops.read |
integer |
query |
False |
Filter by metric.iops.read
metric.duration |
string |
query |
False |
Filter by metric.duration
metric.status |
string |
query |
False |
Filter by metric.status
metric.latency.total |
integer |
query |
False |
Filter by metric.latency.total
metric.latency.other |
integer |
query |
False |
Filter by metric.latency.other
metric.latency.write |
integer |
query |
False |
Filter by metric.latency.write
metric.latency.read |
integer |
query |
False |
Filter by metric.latency.read
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read
wwnn |
string |
query |
False |
Filter by wwnn |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
state |
string |
query |
False |
Filter by state |
comment |
string |
query |
False |
Filter by comment |
wwpn |
string |
query |
False |
Filter by wwpn |
uuid |
string |
query |
False |
Filter by uuid |
statistics.status |
string |
query |
False |
Filter by statistics.status
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.latency_raw.total |
integer |
query |
False |
Filter by statistics.latency_raw.total
statistics.latency_raw.other |
integer |
query |
False |
Filter by statistics.latency_raw.other
statistics.latency_raw.write |
integer |
query |
False |
Filter by statistics.latency_raw.write
statistics.latency_raw.read |
integer |
query |
False |
Filter by statistics.latency_raw.read
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read
name |
string |
query |
False |
Filter by name |
data_protocol |
string |
query |
False |
Filter by data_protocol |
port_address |
string |
query |
False |
Filter by port_address |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
recommend |
Response properties specific to the FC interface placement functionality. See the Interface placement recommendations section of DOC /network/fc/interfaces |
records |
array[fc_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"recommend": {
"messages": [
"arguments": [
"code": "string",
"message": "string"
"code": 5375959,
"message": "Network ports are disabled.",
"severity": "informational"
"records": [
"comment": "string",
"data_protocol": "string",
"location": {
"home_node": {
"name": "node1",
"home_port": {
"name": "0a",
"node": {
"name": "node1"
"node": {
"name": "node1",
"port": {
"name": "0a",
"node": {
"name": "node1"
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 06:20:13 -0500"
"name": "fc_lif1",
"port_address": "5060F",
"state": "string",
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
"uuid": "bce9827d-4d8f-60af-c771-6e8e9af2c6f0",
"wwnn": "20:00:00:50:56:b4:13:01",
"wwpn": "20:00:00:50:56:b4:13:a8"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5373982 |
An invalid WWN was specified. The length is incorrect. |
5373983 |
An invalid WWN was specified. The format is incorrect. |
5374938 |
Query parameter |
5374939 |
Query parameter |
5374940 |
Query parameter |
5375953 |
Query parameter |
5375954 |
Query parameter |
5375955 |
Query parameter |
5375956 |
Query parameter |
5375957 |
Query parameter |
5375958 |
Query parameter |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
fc_interface_recommend_message
arguments |
array[error_arguments] |
The message substitution arguments. |
code |
string |
The message code. Possible messages: ONTAP Error Response Codes Error Code — Description 5375959 — Network ports are disabled. 5375960 — Network ports are enabled, but not reporting a connected FC fabric. 5375961 — The limit for the number of FC network interfaces on a cluster node has been reached. 5375962 — The limit for the number of FC network interfaces on a port has been reached. 5375963 — An HA pair of cluster nodes has a discrepancy in the presence of FC ports. 5375964 — An HA pair of cluster nodes has a discrepancy in support for an FC data protocol. 5375965 — An HA pair of cluster nodes cannot be reached from the same FC fabrics. 5375966 — A cluster node cannot be reached from all of the FC fabrics from which other cluster nodes with FC interfaces in the SVM can be reached. 5375967 — The limit for the number of FC network interfaces on a cluster node has been exceeded. 5375968 — The limit for the number of FC network interfaces on an FC port has been exceeded. 5375969 — The requested number of network interfaces per FC fabric per cluster node has not been achieved. 5375970 — The SVM cannot be reached from all of the FC fabrics to which the cluster is connected. 5375971 — The limit for the number of NVMe network interfaces on a cluster node has been exceeded. 5375972 — The limit for the number of cluster nodes containing NVMe network interfaces for the SVM has been exceeded. 5375973 — The SVM can be reached from a number of FC fabrics other than what is preferred. |
message |
string |
The message text. |
severity |
string |
The severity of the message. Message severities are as follows:
recommend
messages |
Messages describing the results of a FC network interface placement operation or evaluation of caller-proposed locations. |
_links
self |
home_node
_links |
name |
string |
uuid |
string |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
home_port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
node
_links |
name |
string |
uuid |
string |
port
_links |
name |
string |
node |
uuid |
string |
location
The location of the FC interface is defined by the location of its port. An FC port is identified by its UUID, or a combination of its cluster node name and port name. Either the UUID or the cluster node name and port name are required for POST. To move an interface, supply either the port UUID or the cluster node name and port name in a PATCH.
location.node and location.port refer to the current location of the FC interface. This can be different from location.home_node and location.home_port in instances where the FC interface has failed over to its HA partner node. The location.node, location.port, and location.is_home properties are not available for interfaces on the inactive side of a MetroCluster relationship.
home_node |
home_port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
is_home |
boolean |
Indicates if the FC interface is currently on its home node. |
node |
port |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
_links |
name |
string |
uuid |
string |
fc_interface
A Fibre Channel (FC) interface is the logical endpoint for FC network connections to an SVM. An FC interface provides FC access to storage within the interface SVM using either Fibre Channel Protocol or NVMe over Fibre Channel (NVMe/FC).
An FC interface is created on an FC port which is located on a cluster node. The FC port must be specified to identify the location of the interface for a POST or PATCH operation that relocates an interface. You can identify the port by supplying either the cluster node and port names or the port UUID.
_links |
comment |
string |
A user configurable comment. Optional in POST; valid in PATCH. To clear a prior comment, set the property to an empty string in PATCH. |
data_protocol |
string |
The data protocol for which the FC interface is configured. Required in POST. |
enabled |
boolean |
The administrative state of the FC interface. The FC interface can be disabled to block all FC communication with the SVM through this interface. Optional in POST and PATCH; defaults to true (enabled) in POST. |
location |
metric |
Performance numbers, such as IOPS latency and throughput |
name |
string |
The name of the FC interface. Required in POST; optional in PATCH. |
port_address |
string |
The port address of the FC interface. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the FC interface when the SVM performs a port login (PLOGI). This is useful for obtaining statistics and diagnostic information from FC switches. This is a hexadecimal encoded numeric value. |
state |
string |
The current operational state of the FC interface. The state is set to down if the interface is not enabled. If the cluster node hosting the port is down or unavailable, no state value is returned. |
statistics |
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. |
svm |
uuid |
string |
The unique identifier of the FC interface. Required in the URL. |
wwnn |
string |
The world wide node name (WWNN) of the FC interface SVM. The WWNN is generated by ONTAP when Fibre Channel Protocol or the NVMe service is created for the FC interface SVM.
wwpn |
string |
The world wide port name (WWPN) of the FC interface. The WWPN is generated by ONTAP when the FC interface is created.
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
