REST API reference
Retrieve FC interfaces
Retrieves information about Fibre Channel (FC) interfaces, which helps you manage and monitor your network connectivity.
HTTP method and endpoint
GET /network/fc/interfaces
Introduced in
ONTAP 9.6
Usage notes
Retrieves FC interfaces.
  • network interface show
  • vserver fcp interface show
recommend.svm.name
string
query
False
The name of an existing SVM for which to recommend FC interfaces. If neither query parameter recommend.svm.name nor recommend.svm.uuid are provided when recommending FC interfaces, recommendations are made for a new, non-existent SVM.
  • Introduced in: 9.11
recommend.svm.uuid
string
query
False
The UUID of an existing SVM for which to recommend FC interfaces. If neither query parameter recommend.svm.name nor recommend.svm.uuid are provided when recommending FC interfaces, recommendations are made for a new, non-existent SVM.
recommend.data_protocol
string
query
False
The target data protocol for which to recommend FC interfaces. This query parameter is required when recommending FC interfaces.
  • enum: ["fcp", "fc_nvme"]
recommend.interfaces_per_node
integer
query
False
The target number of interfaces per FC fabric per cluster node when recommending FC interfaces. If this query parameter is not provided, the default value is one (1).
  • Default value: 1
  • Max value: 4
  • Min value: 1
recommend.fabrics.name
array[string]
query
False
The names of the FC fabrics to target when recommending FC interfaces. If this query parameter is not provided, FC interfaces will be recommended for each FC fabric discovered.
recommend.nodes.name
array[string]
query
False
The names of the cluster nodes to target when recommending FC interfaces. If this query parameter is not provided, FC interfaces will be recommended for all nodes that have FC network ports supporting target data protocol. Query parameters recommend.nodes.name and recommend.nodes.uuid are mutually exclusive; use either names or UUIDs to identify cluster nodes.
array[string]
query
False
The UUIDs of the cluster nodes to target when recommending FC interfaces. If this query parameter is not provided, FC interfaces will be recommended for all nodes that have FC network ports supporting target data protocol. Query parameters recommend.nodes.name and recommend.nodes.uuid are mutually exclusive; use either names or UUIDs to identify cluster nodes.
recommend.proposed.locations.port.uuid
array[string]
query
False
The UUIDs of the FC ports on which FC interfaces are proposed. A UUID may be supplied multiple times to proposed multiple FC interfaces. FC ports must be enabled, support the target data protocol and be reporting an FC fabric.
port_address
string
query
False
Filter by port_address
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
  • Introduced in: 9.8
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.status
string
query
False
Filter by metric.status
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.duration
string
query
False
Filter by metric.duration
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.write
integer
query
False
Filter by metric.latency.write
location.home_node.name
string
query
False
Filter by location.home_node.name
location.home_node.uuid
string
query
False
Filter by location.home_node.uuid
location.home_port.name
string
query
False
Filter by location.home_port.name
location.home_port.uuid
string
query
False
Filter by location.home_port.uuid
location.home_port.node.name
string
query
False
Filter by location.home_port.node.name
location.node.name
string
query
False
Filter by location.node.name
location.node.uuid
string
query
False
Filter by location.node.uuid
location.port.name
string
query
False
Filter by location.port.name
location.port.uuid
string
query
False
Filter by location.port.uuid
location.port.node.name
string
query
False
Filter by location.port.node.name
location.is_home
boolean
query
False
Filter by location.is_home
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.status
string
query
False
Filter by statistics.status
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
comment
string
query
False
Filter by comment
uuid
string
query
False
Filter by uuid
enabled
boolean
query
False
Filter by enabled
data_protocol
string
query
False
Filter by data_protocol
wwpn
string
query
False
Filter by wwpn
name
string
query
False
Filter by name
wwnn
string
query
False
Filter by wwnn
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
state
string
query
False
Filter by state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
recommend
recommend
Response properties specific to the FC interface placement functionality. See the Interface placement recommendations section of DOC /network/fc/interfaces
records
array[fc_interface]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "recommend": {
    "messages": [
        "arguments": [
            "code": "string",
            "message": "string"
        "code": 5375959,
        "message": "Network ports are disabled.",
        "severity": "informational"
  "records": [
      "comment": "string",
      "data_protocol": "string",
      "location": {
        "home_node": {
          "name": "node1",
        "home_port": {
          "name": "0a",
          "node": {
            "name": "node1"
        "node": {
          "name": "node1",
        "port": {
          "name": "0a",
          "node": {
            "name": "node1"
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 11:20:13 +0000"
      "name": "fc_lif1",
      "port_address": "5060F",
      "state": "string",
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "svm": {
        "name": "svm1",
      "uuid": "bce9827d-4d8f-60af-c771-6e8e9af2c6f0",
      "wwnn": "20:00:00:50:56:b4:13:01",
      "wwpn": "20:00:00:50:56:b4:13:a8"
Status: Default
ONTAP Error Response Codes
Error Code Description
5373982
An invalid WWN was specified. The length is incorrect.
5373983
An invalid WWN was specified. The format is incorrect.
5374938
Query parameter recommend.data_protocol is required when any other recommend query parameters are specified.
5374939
Query parameter recommend.fabrics.name specifies a duplicate FC fabric.
5374940
Query parameter recommend.nodes.name or recommend.nodes.uuid specifies a duplicate node.
5375953
Query parameter recommend.fabrics.name specifies an FC fabric to which no FC port is connected.
5375954
Query parameter recommend.nodes.name or recommend.nodes.uuid specifies a node that does not support the specified data protocol.
5375955
Query parameter recommend.proposed.locations.port.uuid does not specify a valid port or specifies a port that is support the specified data protocol.
5375956
Query parameter recommend.proposed.locations.port.uuid specifies a port that is not located on a node specified by query parameter recommend.nodes.name or recommend.nodes.uuid. If the nodes are to be constrained, only ports on those nodes may be proposed.
5375957
Query parameter recommend.proposed.locations.port.uuid specifies a port that is disabled.
5375958
Query parameter recommend.proposed.locations.port.uuid specifies a port that is not reporting a connected FC fabric.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
fc_interface_recommend_message
arguments
array[error_arguments]
The message substitution arguments.
code
string
The message code. Possible messages:
Error Code — Description
5375959 — Network ports are disabled.
5375960 — Network ports are enabled, but not reporting a connected FC fabric.
5375961 — The limit for the number of FC network interfaces on a cluster node has been reached.
5375962 — The limit for the number of FC network interfaces on a port has been reached.
5375963 — An HA pair of cluster nodes has a discrepancy in the presence of FC ports.
5375964 — An HA pair of cluster nodes has a discrepancy in support for an FC data protocol.
5375965 — An HA pair of cluster nodes cannot be reached from the same FC fabrics.
5375966 — A cluster node cannot be reached from all of the FC fabrics from which other cluster nodes with FC interfaces in the SVM can be reached.
5375967 — The limit for the number of FC network interfaces on a cluster node has been exceeded.
5375968 — The limit for the number of FC network interfaces on an FC port has been exceeded.
5375969 — The requested number of network interfaces per FC fabric per cluster node has not been achieved.
5375970 — The SVM cannot be reached from all of the FC fabrics to which the cluster is connected.
5375971 — The limit for the number of NVMe network interfaces on a cluster node has been exceeded.
5375972 — The limit for the number of cluster nodes containing NVMe network interfaces for the SVM has been exceeded.
5375973 — The SVM can be reached from a number of FC fabrics other than what is preferred.
message
string
The message text.
severity
string
The severity of the message. Message severities are as follows:
  • error - Messages reporting problems that must be corrected before creating the FC network interfaces.
  • warning - Messages indicating issues that need rectifying in order to achieve an optimal configuration.
  • informational - Messages providing relevant information for consideration.
recommend
messages
array[fc_interface_recommend_message]
Messages describing the results of a FC network interface placement operation or evaluation of caller-proposed locations.
self
home_node
_links
_links
name
string
uuid
string
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
home_port
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links
_links
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
node
_links
_links
name
string
uuid
string
port
_links
_links
name
string
node
node
uuid
string
location
The location of the FC interface is defined by the location of its port. An FC port is identified by its UUID, or a combination of its cluster node name and port name. Either the UUID or the cluster node name and port name are required for POST. To move an interface, supply either the port UUID or the cluster node name and port name in a PATCH.
location.node and location.port refer to the current location of the FC interface. This can be different from location.home_node and location.home_port in instances where the FC interface has failed over to its HA partner node. The location.node, location.port, and location.is_home properties are not available for interfaces on the inactive side of a MetroCluster relationship.
home_node
home_node
home_port
home_port
is_home
boolean
Indicates if the FC interface is currently on its home node.
node
node
port
port
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
_links
_links
name
string
uuid
string
fc_interface
A Fibre Channel (FC) interface is the logical endpoint for FC network connections to an SVM. An FC interface provides FC access to storage within the interface SVM using either Fibre Channel Protocol or NVMe over Fibre Channel (NVMe/FC).
An FC interface is created on an FC port which is located on a cluster node. The FC port must be specified to identify the location of the interface for a POST or PATCH operation that relocates an interface. You can identify the port by supplying either the cluster node and port names or the port UUID.
_links
_links
comment
string
A user configurable comment. Optional in POST; valid in PATCH. To clear a prior comment, set the property to an empty string in PATCH.
data_protocol
string
The data protocol for which the FC interface is configured. Required in POST.
enabled
boolean
The administrative state of the FC interface. The FC interface can be disabled to block all FC communication with the SVM through this interface. Optional in POST and PATCH; defaults to true (enabled) in POST.
location
location
metric
metric
name
string
The name of the FC interface. Required in POST; optional in PATCH.
port_address
string
The port address of the FC interface. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the FC interface when the SVM performs a port login (PLOGI).
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a hexadecimal encoded numeric value.
state
string
The current operational state of the FC interface. The state is set to down if the interface is not enabled.
If the cluster node hosting the port is down or unavailable, no state value is returned.
statistics
statistics
svm
svm
uuid
string
The unique identifier of the FC interface. Required in the URL.
wwnn
string
The world wide node name (WWNN) of the FC interface SVM. The WWNN is generated by ONTAP when Fibre Channel Protocol or the NVMe service is created for the FC interface SVM.
  • example: 20:00:00:50:56:b4:13:01
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
wwpn
string
The world wide port name (WWPN) of the FC interface. The WWPN is generated by ONTAP when the FC interface is created.
  • example: 20:00:00:50:56:b4:13:a8
  • readOnly: 1
  • x-nullable: true
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
