Retrieve details for an IP interface
Retrieves details for a specific IP interface to review its configuration and status.
HTTP method and endpoint
GET /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
network interface show
uuid |
string |
path |
True |
IP interface UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
ddns_enabled |
boolean |
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false. |
dns_zone |
string |
Fully qualified DNS zone name |
enabled |
boolean |
The administrative state of the interface. |
ip |
IP information |
ipspace |
Either the UUID or name must be supplied on POST for cluster-scoped objects. |
location |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port. |
metric |
The most recent sample of I/O metrics for the interface. |
name |
string |
Interface name |
probe_port |
integer |
Probe port for Cloud load balancer |
rdma_protocols |
array[string] |
Supported RDMA offload protocols |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
service_policy |
services |
array[string] |
The services associated with the interface. |
state |
string |
The operational state of the interface. |
statistics |
The real time I/O statistics for the interface. |
subnet |
A named subnet. Either UUID or name can be supplied on input. |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST. |
uuid |
string |
The UUID that uniquely identifies the interface. |
vip |
boolean |
True for a VIP interface, whose location is announced via BGP. |
"href": "/api/resourcelink"
"dns_zone": "storage.company.com",
"fail_if_subnet_conflicts": true,
"ip": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ipspace": {
"name": "exchange",
"location": {
"failover": "string",
"home_node": {
"name": "node1",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"node": {
"name": "node1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"metric": {
"duration": "PT15S",
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 06:20:13 -0500"
"name": "dataLif1",
"probe_port": 64001,
"rdma_protocols": [
"roce"
"scope": "string",
"service_policy": {
"name": "default-intercluster",
"services": [
"data_nfs"
"state": "string",
"statistics": {
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"subnet": {
"name": "subnet1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
_links |
name |
string |
uuid |
string |
node
name |
string |
Name of node on which the port is located. |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
port
_links |
name |
string |
node |
uuid |
string |
location
auto_revert |
boolean |
failover |
string |
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI. |
home_node |
home_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
is_home |
boolean |
node |
port |
throughput
The rate of throughput bytes per second observed at the interface.
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
metric
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the interface. |
timestamp |
string |
The timestamp of the performance data. |
service_policy
_links |
name |
string |
uuid |
string |
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
status |
string |
throughput_raw |
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
ip_subnet_reference
_links |
name |
string |
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the subnet. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
