Retrieve details for an IP interface
GET /network/ip/interfaces/{uuid}
Retrieves details for a specific IP interface.
Related ONTAP commands
network interface show
Learn more
uuid  |
string  |
path  |
True  |
IP interface UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
enabled  |
boolean  |
The administrative state of the interface.  |
ip  |
IP information  |
ipspace  |
Either the UUID or name must be supplied on POST for cluster-scoped objects.  |
location  |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node.  |
name  |
string  |
Interface name  |
scope  |
string  |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".  |
service_policy  |
services  |
array[string]  |
The services associated with the interface.  |
state  |
string  |
The operational state of the interface.  |
svm  |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.  |
uuid  |
string  |
The UUID that uniquely identifies the interface.  |
vip  |
boolean  |
True for a VIP interface, whose location is announced via BGP.  |
      "href": "/api/resourcelink"
  "ip": {
    "address": "10.10.10.7",
    "family": "string",
    "netmask": "24"
  "ipspace": {
    "name": "exchange",
  "location": {
    "failover": "string",
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "e1b",
      "node": {
        "name": "node1"
    "node": {
      "name": "node1",
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "dataLif1",
  "scope": "string",
  "service_policy": {
    "name": "default-intercluster",
  "services": [
    "data_nfs"
  "state": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ip_info
IP information
address  |
string  |
IPv4 or IPv6 address  |
family  |
string  |
IPv4 or IPv6  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.  |
ipspace
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
uuid  |
string  |
Broadcast domain UUID  |
home_node
_links  |
name  |
string  |
uuid  |
string  |
node
name  |
string  |
Name of node on which the port is located.  |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links  |
name  |
string  |
node  |
uuid  |
string  |
node
_links  |
name  |
string  |
uuid  |
string  |
port
_links  |
name  |
string  |
node  |
uuid  |
string  |
location
auto_revert  |
boolean  |
failover  |
string  |
Defines where an interface may failover.  |
home_node  |
home_port  |
Port UUID along with readable names. Either the UUID or both names may be supplied on input.  |
is_home  |
boolean  |
node  |
port  |
service_policy
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
