REST API reference
Retrieve the CIFS domain-related information of all SVMs
Retrieves CIFS domain-related information for all SVMs, which can be useful for managing CIFS domain configurations and troubleshooting domain issues.
HTTP method and endpoint
GET /protocols/cifs/domains
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain-related information of all SVMs.
  • vserver cifs domain preferred-dc show
  • vserver cifs domain trusts show
  • vserver cifs domain discovered-servers show
  • vserver cifs domain name-mapping-search show
  • vserver cifs domain schedule show
preferred_dcs.fqdn
string
query
False
Filter by preferred_dcs.fqdn
preferred_dcs.server_ip
string
query
False
Filter by preferred_dcs.server_ip
server_discovery_mode
string
query
False
Filter by server_discovery_mode
  • Introduced in: 9.13
name_mapping.trusted_domains
string
query
False
Filter by name_mapping.trusted_domains
password_schedule.schedule_randomized_minute
integer
query
False
Filter by password_schedule.schedule_randomized_minute
  • Max value: 180
  • Min value: 1
password_schedule.schedule_warn_message
string
query
False
Filter by password_schedule.schedule_warn_message
password_schedule.schedule_last_changed_time
string
query
False
Filter by password_schedule.schedule_last_changed_time
password_schedule.schedule_enabled
boolean
query
False
Filter by password_schedule.schedule_enabled
password_schedule.schedule_weekly_interval
integer
query
False
Filter by password_schedule.schedule_weekly_interval
  • Max value: 52
  • Min value: 1
password_schedule.schedule_description
string
query
False
Filter by password_schedule.schedule_description
trust_relationships.trusted_domains
string
query
False
Filter by trust_relationships.trusted_domains
trust_relationships.home_domain
string
query
False
Filter by trust_relationships.home_domain
trust_relationships.node.name
string
query
False
Filter by trust_relationships.node.name
trust_relationships.node.uuid
string
query
False
Filter by trust_relationships.node.uuid
discovered_servers.node.name
string
query
False
Filter by discovered_servers.node.name
discovered_servers.node.uuid
string
query
False
Filter by discovered_servers.node.uuid
discovered_servers.domain
string
query
False
Filter by discovered_servers.domain
discovered_servers.server_type
string
query
False
Filter by discovered_servers.server_type
discovered_servers.server_ip
string
query
False
Filter by discovered_servers.server_ip
discovered_servers.state
string
query
False
Filter by discovered_servers.state
discovered_servers.server_name
string
query
False
Filter by discovered_servers.server_name
discovered_servers.preference
string
query
False
Filter by discovered_servers.preference
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of CIFS domain records.
records
array[cifs_domain]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "discovered_servers": [
          "domain": "test.com",
          "node": {
            "name": "node1",
          "preference": "string",
          "server_ip": "string",
          "server_name": "string",
          "server_type": "string",
          "state": "string"
      "name_mapping": {
        "trusted_domains": [
          "domain.com"
      "password_schedule": {
        "schedule_day_of_week": "Sunday",
        "schedule_description": "string",
        "schedule_last_changed_time": "string",
        "schedule_time_of_day": 36900,
        "schedule_warn_message": "string"
      "preferred_dcs": [
          "fqdn": "test.com",
          "server_ip": "4.4.4.4"
      "server_discovery_mode": "string",
      "svm": {
        "name": "svm1",
      "trust_relationships": [
          "home_domain": "string",
          "node": {
            "name": "node1",
            "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
ad_domain
Specifies the credentials of a user with permissions to reset the password in the organizational unit for the machine account.
self
node
_links
_links
name
string
uuid
string
discovered_servers
domain
string
Fully Qualified Domain Name.
node
node
preference
string
Server Preference
server_ip
string
Server IP address
server_name
string
Server Name
server_type
string
Server Type
state
string
Server status
name_mapping
Specifies the name mapping search records.
trusted_domains
array[string]
password_schedule
Specifies the password schedule records.
string
Day of the week for password change schedule.
string
Schedule description.
schedule_enabled
boolean
Is password schedule enabled.
string
Last successful password change time.
integer
Minutes within which schedule start can be randomized.
string
Start time for password change schedule.
string
Warning message in case job is deleted.
integer
Interval in weeks for password change schedule.
preferred_dcs
fqdn
string
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
svm
_links
_links
name
string
uuid
string
trust_relationships
home_domain
string
Home Domain Name
node
node
trusted_domains
array[string]
Trusted Domain Name
cifs_domain
ad_domain
ad_domain
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
name_mapping
name_mapping
password_schedule
password_schedule
preferred_dcs
array[preferred_dcs]
Specifies the preferred DC records.
string
Specifies the mode of server discovery.
svm
svm
trust_relationships
array[trust_relationships]
Specifies the trusted domain records.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
