Retrieve the CIFS domain-related information of all SVMs
Accesses information about CIFS domains associated with all SVMs, helping you understand the domain configurations and relationships across your storage environment.
HTTP method and endpoint
GET /protocols/cifs/domains
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain-related information of all SVMs.
Related ONTAP commands
vserver cifs domain preferred-dc show -
vserver cifs domain trusts show -
vserver cifs domain discovered-servers show -
vserver cifs domain name-mapping-search show -
vserver cifs domain schedule show
Learn more
preferred_dcs.server_ip |
string |
query |
False |
Filter by preferred_dcs.server_ip |
preferred_dcs.fqdn |
string |
query |
False |
Filter by preferred_dcs.fqdn |
trust_relationships.home_domain |
string |
query |
False |
Filter by trust_relationships.home_domain |
trust_relationships.node.uuid |
string |
query |
False |
Filter by trust_relationships.node.uuid |
trust_relationships.node.name |
string |
query |
False |
Filter by trust_relationships.node.name |
trust_relationships.trusted_domains |
string |
query |
False |
Filter by trust_relationships.trusted_domains |
discovered_servers.server_name |
string |
query |
False |
Filter by discovered_servers.server_name |
discovered_servers.domain |
string |
query |
False |
Filter by discovered_servers.domain |
discovered_servers.state |
string |
query |
False |
Filter by discovered_servers.state |
discovered_servers.server_ip |
string |
query |
False |
Filter by discovered_servers.server_ip |
discovered_servers.node.uuid |
string |
query |
False |
Filter by discovered_servers.node.uuid |
discovered_servers.node.name |
string |
query |
False |
Filter by discovered_servers.node.name |
discovered_servers.preference |
string |
query |
False |
Filter by discovered_servers.preference |
discovered_servers.server_type |
string |
query |
False |
Filter by discovered_servers.server_type |
password_schedule.schedule_description |
string |
query |
False |
Filter by password_schedule.schedule_description |
password_schedule.schedule_last_changed_time |
string |
query |
False |
Filter by password_schedule.schedule_last_changed_time |
password_schedule.schedule_enabled |
boolean |
query |
False |
Filter by password_schedule.schedule_enabled |
password_schedule.schedule_weekly_interval |
integer |
query |
False |
Filter by password_schedule.schedule_weekly_interval |
password_schedule.schedule_warn_message |
string |
query |
False |
Filter by password_schedule.schedule_warn_message |
password_schedule.schedule_randomized_minute |
integer |
query |
False |
Filter by password_schedule.schedule_randomized_minute |
name_mapping.trusted_domains |
string |
query |
False |
Filter by name_mapping.trusted_domains |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of CIFS domain records. |
records |
array[cifs_domain] |
"next": {
"href": "/api/resourcelink"
"records": [
"discovered_servers": [
"domain": "test.com",
"node": {
"name": "node1",
"preference": "string",
"server_ip": "string",
"server_name": "string",
"server_type": "string",
"state": "string"
"name_mapping": {
"trusted_domains": [
"domain.com"
"password_schedule": {
"schedule_description": "string",
"schedule_last_changed_time": "string",
"schedule_warn_message": "string"
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4"
"svm": {
"name": "svm1",
"trust_relationships": [
"home_domain": "string",
"node": {
"name": "node1",
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
discovered_servers
domain |
string |
Fully Qualified Domain Name. |
node |
preference |
string |
Server Preference |
server_ip |
string |
Server IP address |
server_name |
string |
Server Name |
server_type |
string |
Server Type |
state |
string |
Server status |
name_mapping
Specifies the name mapping search records.
trusted_domains |
array[string] |
password_schedule
Specifies the password schedule records.
string |
Schedule description. |
schedule_enabled |
boolean |
Is password schedule enabled. |
string |
Last successful password change time. |
integer |
Minutes within which schedule start can be randomized. |
string |
Warning message in case job is deleted. |
integer |
Interval in weeks for password change schedule. |
preferred_dcs
fqdn |
string |
server_ip |
string |
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
trust_relationships
home_domain |
string |
Home Domain Name |
node |
trusted_domains |
array[string] |
Trusted Domain Name |
cifs_domain
discovered_servers |
array[discovered_servers] |
Specifies the discovered servers records. |
name_mapping |
Specifies the name mapping search records. |
password_schedule |
Specifies the password schedule records. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred DC records. |
svm |
trust_relationships |
array[trust_relationships] |
Specifies the trusted domain records. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
