REST API reference
Retrieve the local user information for a user and SVM
Accesses local user information for a specified user and storage virtual machine (SVM). This is useful for managing and reviewing user configurations within your ONTAP environment.
HTTP method and endpoint
GET /protocols/cifs/local-users/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves local user information for the specified user and SVM.
Advanced properties
  • membership
  • vserver cifs users-and-groups local-user show
  • vserver cifs users-and-groups local-user show-membership
sid
string
path
True
Local user SID
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
account_disabled
boolean
Indicates whether the user account is enabled or disabled.
description
string
Description for the local user.
full_name
string
User's full name.
membership
array[membership]
Specifies local groups of which this local user is a member.
name
string
Local user name. The maximum supported length of an user name is 20 characters.
sid
string
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method.
svm
svm
      "href": "/api/resourcelink"
  "description": "This is local user.",
  "full_name": "user name",
  "membership": [
      "name": "SMB_SERVER01\\group",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
  "name": "SMB_SERVER01\\user",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
membership
_links
_links
name
string
Local group name. The maximum supported length of a group name is 256 characters.
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
