Retrieve the local user information for a user and SVM
Accesses local user information for a specified user and storage virtual machine (SVM). This is useful for managing and reviewing user configurations within your ONTAP environment.
HTTP method and endpoint
GET /protocols/cifs/local-users/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves local user information for the specified user and SVM.
Advanced properties
membership
Related ONTAP commands
vserver cifs users-and-groups local-user show -
vserver cifs users-and-groups local-user show-membership
Learn more
sid |
string |
path |
True |
Local user SID |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
account_disabled |
boolean |
Indicates whether the user account is enabled or disabled. |
description |
string |
Description for the local user. |
full_name |
string |
User's full name. |
membership |
array[membership] |
Specifies local groups of which this local user is a member. |
name |
string |
Local user name. The maximum supported length of an user name is 20 characters. |
sid |
string |
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method. |
svm |
"href": "/api/resourcelink"
"description": "This is local user.",
"full_name": "user name",
"membership": [
"name": "SMB_SERVER01\\group",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
"name": "SMB_SERVER01\\user",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
membership
_links |
name |
string |
Local group name. The maximum supported length of a group name is 256 characters. |
sid |
string |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
