Retrieve a share-level ACL on a CIFS share
Retrieves the share-level ACL for a CIFS share to understand and manage access permissions for that share.
HTTP method and endpoint
GET /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced in
ONTAP 9.6
Usage notes
Retrieves the share-level ACL on a CIFS share.
Related ONTAP commands
vserver cifs share access-control show
share |
string |
path |
True |
CIFS Share Name |
user_or_group |
string |
query |
False |
Filter by user_or_group |
type |
string |
query |
False |
Filter by type |
permission |
string |
query |
False |
Filter by permission |
svm.name |
string |
query |
False |
Filter by svm.name
sid |
string |
query |
False |
Filter by sid
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_share_acl] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"permission": "string",
"share": "string",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
"type": "string",
"user_or_group": "ENGDOMAIN\\ad_user"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
The permissions that users and groups have on a CIFS share.
_links |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
share |
string |
CIFS share name |
sid |
string |
Specifies the user or group secure identifier (SID). |
svm |
type |
string |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group |
string |
Specifies the user or group name to add to the access control list of a CIFS share. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
