REST API reference
Retrieve a share-level ACL on a CIFS share
GET /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced In: 9.6
Retrieves the share-level ACL on a CIFS share.
  • vserver cifs share access-control show
share
string
path
True
CIFS Share Name
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.9
sid
string
query
False
Filter by sid
  • Introduced in: 9.13
type
string
query
False
Filter by type
permission
string
query
False
Filter by permission
unix_id
integer
query
False
Filter by unix_id
  • Introduced in: 9.16
user_or_group
string
query
False
Filter by user_or_group
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_share_acl]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "permission": "string",
      "share": "string",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "svm": {
        "name": "svm1",
      "type": "string",
      "unix_id": 100,
      "user_or_group": "ENGDOMAIN\\ad_user"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
cifs_share_acl
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
share
string
CIFS share name
sid
string
Specifies the user or group secure identifier (SID).
svm
svm
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
unix_id
integer
Specifies the UNIX user or group identifier (UID/GID).
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
