REST API reference
Retrieve an FPolicy persistent store configuration for an SVM
Retrieves the FPolicy persistent store configuration for a specific SVM to view its current settings and ensure proper policy management.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced in
ONTAP 9.14
Usage notes
Retrieves a specific FPolicy persistent store configuration for an SVM.
  • fpolicy persistent-store show
name
string
path
True
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
name
string
The name specified for the FPolicy persistent store.
svm
svm
volume
string
The specified volume to store the events for the FPolicy persistent store.
  "name": "ps1",
  "svm": {
    "uuid": "string"
  "volume": "psvol"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
svm
uuid
string
SVM UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
