REST API reference
Retrieve an FPolicy persistent store configuration for an SVM
Obtains the FPolicy persistent store configuration for a specific SVM. This information is useful for managing and reviewing FPolicy settings within your storage environment.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
Introduced in
ONTAP 9.14
Usage notes
Retrieves a specific FPolicy Persistent Store configuration for an SVM.
  • fpolicy persistent-store show
name
string
path
True
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
autosize_mode
string
Autosize mode for the volume. grow ‐ Volume automatically grows in response to the amount of space used. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled.
name
string
The name specified for the FPolicy Persistent Store.
size
integer
The size of the Persistent Store volume, in bytes.
svm
svm
volume
string
The specified volume to store the events for the FPolicy Persistent Store.
  "autosize_mode": "string",
  "name": "ps1",
  "size": "100M",
  "svm": {
    "uuid": "string"
  "volume": "psvol"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
svm
uuid
string
SVM UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
