Retrieve initiator groups
Retrieves initiator groups to view and manage the configurations associated with your storage protocols. This operation helps you understand and organize access settings for your networked storage environment.
HTTP method and endpoint
GET /protocols/san/igroups
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
connectivity_tracking.* -
igroups.* -
lun_maps.* -
parent_igroups.* -
target.*
Related ONTAP commands
lun igroup show -
lun mapping show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
parent_igroups.name |
string |
query |
False |
Filter by parent_igroups.name
parent_igroups.comment |
string |
query |
False |
Filter by parent_igroups.comment
parent_igroups.uuid |
string |
query |
False |
Filter by parent_igroups.uuid
protocol |
string |
query |
False |
Filter by protocol |
connectivity_tracking.required_nodes.name |
string |
query |
False |
Filter by connectivity_tracking.required_nodes.name
connectivity_tracking.required_nodes.uuid |
string |
query |
False |
Filter by connectivity_tracking.required_nodes.uuid
connectivity_tracking.connection_state |
string |
query |
False |
Filter by connectivity_tracking.connection_state
connectivity_tracking.alerts.summary.code |
string |
query |
False |
Filter by connectivity_tracking.alerts.summary.code
connectivity_tracking.alerts.summary.arguments.code |
string |
query |
False |
Filter by connectivity_tracking.alerts.summary.arguments.code
connectivity_tracking.alerts.summary.arguments.message |
string |
query |
False |
Filter by connectivity_tracking.alerts.summary.arguments.message
connectivity_tracking.alerts.summary.message |
string |
query |
False |
Filter by connectivity_tracking.alerts.summary.message
lun_maps.lun.node.name |
string |
query |
False |
Filter by lun_maps.lun.node.name |
lun_maps.lun.node.uuid |
string |
query |
False |
Filter by lun_maps.lun.node.uuid |
lun_maps.lun.name |
string |
query |
False |
Filter by lun_maps.lun.name |
lun_maps.lun.uuid |
string |
query |
False |
Filter by lun_maps.lun.uuid |
lun_maps.logical_unit_number |
integer |
query |
False |
Filter by lun_maps.logical_unit_number |
initiators.connectivity_tracking.connection_state |
string |
query |
False |
Filter by initiators.connectivity_tracking.connection_state
initiators.igroup.uuid |
string |
query |
False |
Filter by initiators.igroup.uuid |
initiators.igroup.name |
string |
query |
False |
Filter by initiators.igroup.name
initiators.name |
string |
query |
False |
Filter by initiators.name
initiators.comment |
string |
query |
False |
Filter by initiators.comment
portset.name |
string |
query |
False |
Filter by portset.name
portset.uuid |
string |
query |
False |
Filter by portset.uuid
uuid |
string |
query |
False |
Filter by uuid |
target.vendor_id |
string |
query |
False |
Filter by target.vendor_id
target.product_id |
string |
query |
False |
Filter by target.product_id
target.firmware_revision |
string |
query |
False |
Filter by target.firmware_revision
os_type |
string |
query |
False |
Filter by os_type |
name |
string |
query |
False |
Filter by name
igroups.uuid |
string |
query |
False |
Filter by igroups.uuid
igroups.comment |
string |
query |
False |
Filter by igroups.comment
igroups.name |
string |
query |
False |
Filter by igroups.name
delete_on_unmap |
boolean |
query |
False |
Filter by delete_on_unmap |
supports_igroups |
boolean |
query |
False |
Filter by supports_igroups
comment |
string |
query |
False |
Filter by comment
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[igroup] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "string",
"connectivity_tracking": {
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"connection_state": "string",
"required_nodes": [
"name": "node1",
"igroups": [
"name": "igroup1",
"initiators": [
"igroup": {
"name": "igroup1",
"name": "iqn.1998-01.com.corp.iscsi:name1"
"lun_maps": [
"logical_unit_number": 0,
"lun": {
"name": "lun1",
"node": {
"name": "node1",
"name": "igroup1",
"os_type": "string",
"portset": {
"name": "portset1",
"protocol": "string",
"svm": {
"name": "svm1",
"target": {
"firmware_revision": "9111",
"product_id": "LUN C-Mode",
"vendor_id": "NETAPP"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state of the initiator group.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
alerts
summary |
A user friendly message describing the connection state of the initiator group. |
required_nodes
_links |
name |
string |
uuid |
string |
An overview of the connections to ONTAP by the initiators in this group.
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
required_nodes |
array[required_nodes] |
Nodes to which the initiators in this group should be connected to ensure reliable service. This is the collection of any node hosting a LUN mapped to this igroup as well as the HA partners of those nodes. |
igroup_child
_links |
comment |
string |
A comment available for use by the administrator. |
igroups |
array[] |
Further nested initiator groups. |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
A link to the initiator with connectivity information relevant to its membership of this initiator group.
href |
string |
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
href |
string |
_links
connectivity_tracking |
A link to the initiator with connectivity information relevant to its membership of this initiator group. |
self |
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group. |
Overview of the initiator's connections to ONTAP.
connection_state |
string |
Connection state. |
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
_links |
name |
string |
uuid |
string |
initiators
_links |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
igroup |
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
node
_links |
name |
string |
uuid |
string |
lun
The LUN to which the initiator group is mapped.
_links |
name |
string |
The name of the LUN. |
node |
uuid |
string |
The unique identifier of the LUN. |
lun_maps
A LUN map with which the initiator group is associated.
_links |
integer |
The logical unit number assigned to the LUN for initiators in the initiator group. |
lun |
The LUN to which the initiator group is mapped. |
portset
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset.
Optional in POST and PATCH. PATCH portset.name to an empty string ("") to unbind a portset from the initiator group.
_links |
name |
string |
The name of the portset. |
uuid |
string |
The unique identifier of the portset. |
svm
_links |
name |
string |
uuid |
string |
target
Properties of the SCSI target to which the initiator group provides access.
firmware_revision |
string |
The firmware revision of the SCSI target specific to the OS type of the initiator group. |
product_id |
string |
The product ID of the SCSI target. |
vendor_id |
string |
The vendor ID of the SCSI target. |
igroup
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host endpoints.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. When a parent initiator group is mapped, it inherits all of the initiators of any initiator groups nested below it. If any nested initiator group is modified to contain different initiators, the parent initiator groups inherit the change. A parent can have many nested initiator groups and an initiator group can be nested under multiple parents. Initiators can only be added or removed from the initiator group that directly contains them. The maximum supported depth of nesting is three layers.
Best practice when using nested initiator groups is to match host hierarchies. A single initiator group should correspond to a single host. If a LUN needs to be mapped to multiple hosts, the initiator groups representing those hosts should be aggregated into a parent initiator group and the LUN should be mapped to that initiator group. For multi-ported hosts, initiators have a comment property where the port corresponding to the initiator can be documented.
An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once. With the introduction of nestable initiator groups, best practice is to use the hierarchy such that an initiator is only a direct member of a single initiator group, and that initiator group can then be referenced by other initiator groups.
All initiators or nested initiator groups in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed). Initiator groups within a nested hierarchy may not have conflicting protocols.
Zero or more initiators or nested initiator groups can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. Initiator groups containing other initiator groups report the aggregated list of initiators from all nested initiator groups, but modifications of the initiator list must be performed on the initiator group that directly contains the initiators. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
_links |
comment |
string |
delete_on_unmap |
boolean |
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created. |
igroups |
array[igroup_child] |
The initiator groups that are members of the group. Optional in POST. This property is mutually exclusive with the initiators property during POST. This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregatation of all initiators in any nested initiator groups. After creation, nested initiator groups can be added or removed from the initiator group using the |
initiators |
array[initiators] |
The initiators that are members of the group or any group nested below this group. Optional in POST. This property is mutually exclusive with the igroups property during POST. During GET, this array contains initiators that are members of this group or any nested initiator groups below this group. When initiators of nested groups are returned, they include links to the initiator group that directly contains the initiator. Zero or more initiators can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the |
lun_maps |
array[lun_maps] |
All LUN maps with which the initiator is associated. If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved. There is an added computational cost to retrieving property values for |
name |
string |
The name of the initiator group. Required in POST; optional in PATCH. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH. |
parent_igroups |
array[] |
The initiator groups that contain this initiator group as as member. |
portset |
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset. Optional in POST and PATCH. PATCH |
protocol |
string |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed. The protocol of an initiator group cannot be changed after creation of the group. |
supports_igroups |
boolean |
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The |
svm |
target |
Properties of the SCSI target to which the initiator group provides access. |
uuid |
string |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
