REST API reference
Retrieve initiator groups
GET /protocols/san/igroups
Introduced In: 9.6
Retrieves initiator groups.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connectivity_tracking.*
  • igroups.*
  • lun_maps.*
  • parent_igroups.*
  • target.*
  • lun igroup show
  • lun mapping show
target.vendor_id
string
query
False
Filter by target.vendor_id
  • Introduced in: 9.11
target.product_id
string
query
False
Filter by target.product_id
target.firmware_revision
string
query
False
Filter by target.firmware_revision
supports_igroups
boolean
query
False
Filter by supports_igroups
  • Introduced in: 9.9
name
string
query
False
Filter by name
  • maxLength: 96
  • minLength: 1
replication.state
string
query
False
Filter by replication.state
  • Introduced in: 9.15
replication.error.summary.arguments.message
string
query
False
Filter by replication.error.summary.arguments.message
replication.error.summary.arguments.code
string
query
False
Filter by replication.error.summary.arguments.code
replication.error.summary.code
string
query
False
Filter by replication.error.summary.code
replication.error.summary.message
string
query
False
Filter by replication.error.summary.message
replication.error.igroup.name
string
query
False
Filter by replication.error.igroup.name
  • maxLength: 96
  • minLength: 1
replication.error.igroup.local_svm
boolean
query
False
Filter by replication.error.igroup.local_svm
replication.error.igroup.uuid
string
query
False
Filter by replication.error.igroup.uuid
replication.peer_svm.name
string
query
False
Filter by replication.peer_svm.name
replication.peer_svm.uuid
string
query
False
Filter by replication.peer_svm.uuid
igroups.uuid
string
query
False
Filter by igroups.uuid
igroups.name
string
query
False
Filter by igroups.name
  • maxLength: 96
  • minLength: 1
igroups.comment
string
query
False
Filter by igroups.comment
  • maxLength: 254
  • minLength: 0
protocol
string
query
False
Filter by protocol
uuid
string
query
False
Filter by uuid
comment
string
query
False
Filter by comment
  • maxLength: 254
  • minLength: 0
connectivity_tracking.connection_state
string
query
False
Filter by connectivity_tracking.connection_state
connectivity_tracking.required_nodes.name
string
query
False
Filter by connectivity_tracking.required_nodes.name
connectivity_tracking.required_nodes.uuid
string
query
False
Filter by connectivity_tracking.required_nodes.uuid
connectivity_tracking.alerts.summary.arguments.message
string
query
False
Filter by connectivity_tracking.alerts.summary.arguments.message
connectivity_tracking.alerts.summary.arguments.code
string
query
False
Filter by connectivity_tracking.alerts.summary.arguments.code
connectivity_tracking.alerts.summary.code
string
query
False
Filter by connectivity_tracking.alerts.summary.code
connectivity_tracking.alerts.summary.message
string
query
False
Filter by connectivity_tracking.alerts.summary.message
initiators.proximity.peer_svms.name
string
query
False
Filter by initiators.proximity.peer_svms.name
initiators.proximity.peer_svms.uuid
string
query
False
Filter by initiators.proximity.peer_svms.uuid
initiators.proximity.local_svm
boolean
query
False
Filter by initiators.proximity.local_svm
initiators.name
string
query
False
Filter by initiators.name
  • maxLength: 96
  • minLength: 1
initiators.comment
string
query
False
Filter by initiators.comment
  • maxLength: 254
  • minLength: 0
initiators.connectivity_tracking.connection_state
string
query
False
Filter by initiators.connectivity_tracking.connection_state
initiators.igroup.name
string
query
False
Filter by initiators.igroup.name
  • maxLength: 96
  • minLength: 1
initiators.igroup.uuid
string
query
False
Filter by initiators.igroup.uuid
delete_on_unmap
boolean
query
False
Filter by delete_on_unmap
portset.uuid
string
query
False
Filter by portset.uuid
portset.name
string
query
False
Filter by portset.name
  • maxLength: 96
  • minLength: 1
lun_maps.logical_unit_number
integer
query
False
Filter by lun_maps.logical_unit_number
lun_maps.lun.name
string
query
False
Filter by lun_maps.lun.name
lun_maps.lun.node.name
string
query
False
Filter by lun_maps.lun.node.name
lun_maps.lun.node.uuid
string
query
False
Filter by lun_maps.lun.node.uuid
lun_maps.lun.uuid
string
query
False
Filter by lun_maps.lun.uuid
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
os_type
string
query
False
Filter by os_type
parent_igroups.comment
string
query
False
Filter by parent_igroups.comment
  • maxLength: 254
  • minLength: 0
parent_igroups.name
string
query
False
Filter by parent_igroups.name
  • maxLength: 96
  • minLength: 1
parent_igroups.uuid
string
query
False
Filter by parent_igroups.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[igroup]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "connectivity_tracking": {
        "alerts": [
            "summary": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "message": "entry doesn't exist"
        "connection_state": "string",
        "required_nodes": [
            "name": "node1",
      "igroups": [
          "igroups": [
            null
          "name": "igroup1",
      "initiators": [
          "igroup": {
            "name": "igroup1",
          "name": "iqn.1998-01.com.corp.iscsi:name1",
          "proximity": {
            "peer_svms": [
                "name": "peer1",
                "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
      "lun_maps": [
          "logical_unit_number": 0,
          "lun": {
            "name": "lun1",
            "node": {
              "name": "node1",
      "name": "igroup1",
      "os_type": "string",
      "parent_igroups": [
          "name": "igroup1",
          "parent_igroups": [
            null
      "portset": {
        "name": "portset1",
      "protocol": "string",
      "replication": {
        "error": {
          "igroup": {
            "name": "igroup1",
          "summary": {
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
        "peer_svm": {
          "name": "peer1",
        "state": "string"
      "svm": {
        "name": "svm1",
      "target": {
        "firmware_revision": "9111",
        "product_id": "LUN C-Mode",
        "vendor_id": "NETAPP"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state of the initiator group.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
alerts
summary
summary
required_nodes
_links
_links
name
string
uuid
string
An overview of the connections to ONTAP by the initiators in this group.
alerts
array[alerts]
connection_state
string
Connection state.
required_nodes
array[required_nodes]
Nodes to which the initiators in this group should be connected to ensure reliable service. This is the collection of any node hosting a LUN mapped to this igroup as well as the HA partners of those nodes.
igroup_child
_links
_links
comment
string
A comment available for use by the administrator.
igroups
array[igroup_child]
Further nested initiator groups.
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
A link to the initiator with connectivity information relevant to its membership of this initiator group.
string
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
string
self
self
Overview of the initiator's connections to ONTAP.
connection_state
string
Connection state.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
_links
_links
name
string
uuid
string
peer_svms
A reference to an SVM peer relationship.
_links
_links
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for an initiator, the sub-object will not be present in GET.
These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The proximity sub-object for an initiator is set in POST and PATCH in its entirety and replaces any previously set proximity for the initiator within the SVM for the initiator within the SVM. The local_svm property must always be set to true or false when setting the proximity property. To clear any previously set proximity, POST or PATCH the proximity object to null.
local_svm
boolean
A boolean that indicates if the initiator is proximal to the SVM of the containing initiator group. This is required for any POST or PATCH that includes the proximity sub-object.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the initiator is proximal.
initiators
_links
_links
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
  • readOnly: 1
igroup
igroup
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
proximity
proximity
node
_links
_links
name
string
uuid
string
lun
The LUN to which the initiator group is mapped.
_links
_links
name
string
The name of the LUN.
node
node
uuid
string
The unique identifier of the LUN.
lun_maps
A LUN map with which the initiator group is associated.
_links
_links
logical_unit_number
integer
The logical unit number assigned to the LUN for initiators in the initiator group.
lun
lun
igroup_parent
_links
_links
comment
string
name
string
parent_igroups
array[igroup_parent]
The initiator groups that contain this initiator group as a member.
uuid
string
portset
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset.
In a nested initiator group hierarchy, only a portset bound to the initiator group at the same level at which it is mapped, applies; portsets bound to parent or child initiator groups are ignored.
Optional in POST and PATCH. To unbind a portset from the initiator group, PATCH the portset object to null, or PATCH portset.name to an empty string ("").
_links
_links
name
string
The name of the portset.
uuid
string
The unique identifier of the portset.
igroup
local_svm
boolean
Indicates whether the reported igroup is on the local SVM or the peer SVM. When deleting a replicated igroup, the local copy is deleted first and then the peer copy is deleted. If the error is encountered between these two operations and only the peer igroup remains, the peer igroup is reported and the problem might need to be corrected on the peer cluster.
name
string
uuid
string
summary
A user friendly message describing the error.
arguments
Message arguments
code
string
Error code
message
string
Error message
error
Information about asynchronous errors encountered while replicating this igroup. Igroups within a peering relationship are replicated in the same stream, so the error reported here might be related to this igroup or a prior replicated igroup that is now blocking the replication of this igroup. Both the error information and the igroup encountering the error are reported. If the error is configuration related, it can be corrected on the referenced igroup. The replication is retried using exponential backoff up to a maximum of one retry every 5 minutes. Every operation on the same stream triggers an immediate retry and restarts the exponential backoff starting with a 1 second delay. If the error is system related, the retries should correct the error when the system enters a healthy state.
igroup
igroup
summary
summary
peer_svm
The peered SVM to which the initiator group should be replicated. Optional in POST and PATCH. To clear any previously set replication peer, PATCH the replication.peer_svm object to null.
_links
_links
name
string
uuid
string
replication
Properties related to initiator group replication.
error
error
peer_svm
peer_svm
state
string
The state of the replication queue associated with this igroup. If this igroup is not in the replication queue, the state is reported as ok. If this igroup is in the replication queue, but no errors have been encountered, the state is reported as replicating. If this igroup is in the replication queue and the queue is blocked by an error, the state is reported as error. When in the error state, additional context is provided by the replication.error property.
svm
_links
_links
name
string
uuid
string
target
Properties of the SCSI target to which the initiator group provides access.
firmware_revision
string
The firmware revision of the SCSI target specific to the OS type of the initiator group.
product_id
string
The product ID of the SCSI target.
vendor_id
string
The vendor ID of the SCSI target.
igroup
An initiator group (igroup) is a collection of Fibre Channel (FC) world wide port names (WWPNs), and/or iSCSI Qualified Names (IQNs), and/or iSCSI EUIs (Extended Unique Identifiers) that identify host endpoints.
Initiator groups are used to control which hosts can access specific LUNs. To grant access to a LUN from one or more hosts, create an initiator group containing the host initiator names, then create a LUN map that associates the initiator group with the LUN.
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. When a parent initiator group is mapped, it inherits all of the initiators of any initiator groups nested below it. If any nested initiator group is modified to contain different initiators, the parent initiator groups inherit the change. A parent can have many nested initiator groups and an initiator group can be nested under multiple parents. Initiators can only be added or removed from the initiator group that directly contains them. The maximum supported depth of nesting is three layers.
Best practice when using nested initiator groups is to match host hierarchies. A single initiator group should correspond to a single host. If a LUN needs to be mapped to multiple hosts, the initiator groups representing those hosts should be aggregated into a parent initiator group and the LUN should be mapped to that initiator group. For multi-ported hosts, initiators have a comment property where the port corresponding to the initiator can be documented.
An initiator can appear in multiple initiator groups. An initiator group can be mapped to multiple LUNs. A specific initiator can be mapped to a specific LUN only once. With the introduction of nestable initiator groups, best practice is to use the hierarchy such that an initiator is only a direct member of a single initiator group, and that initiator group can then be referenced by other initiator groups.
All initiators or nested initiator groups in an initiator group must be from the same operating system. The initiator group's operating system is specified when the initiator group is created.
When an initiator group is created, the protocol property is used to restrict member initiators to Fibre Channel (fcp), iSCSI (iscsi), or both (mixed). Initiator groups within a nested hierarchy may not have conflicting protocols.
Zero or more initiators or nested initiator groups can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. Initiator groups containing other initiator groups report the aggregated list of initiators from all nested initiator groups, but modifications of the initiator list must be performed on the initiator group that directly contains the initiators. See link:post-protocols-san-igroups-initiators(#-san-igroup-initiator-create)anddelete-protocols-san-igroups-initiators-.htmlPOST /protocols/san/igroups/{igroup.uuid}/initiators and [DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name}] for more details.
_links
_links
comment
string
  • readOnly: 1
delete_on_unmap
boolean
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created.
igroups
array[igroup_child]
The existing initiator groups that are members of the group. Optional in POST.
This property is mutually exclusive with the initiators property during POST.
This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the igroups property of the child initiator group.
Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregation of all initiators in any nested initiator groups.
After creation, nested initiator groups can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/igroups endpoint. See link:post-protocols-san-igroups-igroups(#-san-igroup-nested-create)anddelete-protocols-san-igroups-igroups-.htmlPOST /protocols/san/igroups/{igroup.uuid}/igroups and [DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid}] for more details.
initiators
array[initiators]
The initiators that are members of the group or any group nested below this group. Optional in POST.
This property is mutually exclusive with the igroups property during POST.
During GET, this array contains initiators that are members of this group or any nested initiator groups below this group. When initiators of nested groups are returned, they include links to the initiator group that directly contains the initiator.
Zero or more initiators can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. See link:post-protocols-san-igroups-initiators(#-san-igroup-initiator-create)anddelete-protocols-san-igroups-initiators-.htmlPOST /protocols/san/igroups/{igroup.uuid}/initiators and [DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name}] for more details.
lun_maps
array[lun_maps]
All LUN maps with which the initiator is associated.
If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved.
There is an added computational cost to retrieving property values for lun_maps. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
parent_igroups
portset
portset
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
replication
replication
supports_igroups
boolean
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The initiators.name property cannot be used to determine this via a query because it reports initiators inherited from nested igroups.
svm
svm
target
target
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
