REST API reference
Retrieve a Vscan On-Demand policy
Retrieves the Vscan On-Demand policy to access configuration details for scanning tasks on demand. This allows you to verify and manage the policy settings applied to your storage virtual machine.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/on-demand-policies
Introduced in
ONTAP 9.6
  • vserver vscan on-demand-task show
name
string
query
False
Filter by name
  • maxLength: 256
  • minLength: 1
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.10
scope.exclude_extensions
string
query
False
Filter by scope.exclude_extensions
scope.scan_without_extension
boolean
query
False
Filter by scope.scan_without_extension
scope.exclude_paths
string
query
False
Filter by scope.exclude_paths
  • maxLength: 255
  • minLength: 1
scope.max_file_size
integer
query
False
Filter by scope.max_file_size
  • Max value: 1099511627776
  • Min value: 1024
scope.include_extensions
string
query
False
Filter by scope.include_extensions
schedule.name
string
query
False
Filter by schedule.name
schedule.uuid
string
query
False
Filter by schedule.uuid
log_path
string
query
False
Filter by log_path
scan_paths
string
query
False
Filter by scan_paths
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan_on_demand]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "log_path": "/vol0/report_dir",
      "name": "task-1",
      "scan_paths": [
        "/vol1/",
        "/vol2/cifs/"
      "schedule": {
        "name": "weekly",
      "scope": {
        "exclude_extensions": [
          "mp3",
          "mp4"
        "exclude_paths": [
          "/vol1/cold-files/",
          "/vol1/cifs/names"
        "include_extensions": [
          "vmdk",
          "mp*"
        "max_file_size": 10737418240
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
Schedule of the task.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
boolean
Specifies whether or not files without any extension can be scanned.
svm
_links
_links
name
string
uuid
string
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path
string
The path from the Vserver root where the task report is created.
name
string
On-Demand task name
scan_paths
array[string]
List of paths that need to be scanned.
schedule
schedule
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
