REST API reference
Retrieve a Vscan On-Demand policy
Accesses the Vscan On-Demand policy to examine its settings and understand how it is configured for scanning operations.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/on-demand-policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves the Vscan On-Demand policy.
  • vserver vscan on-demand-task show
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.10
scan_paths
string
query
False
Filter by scan_paths
log_path
string
query
False
Filter by log_path
name
string
query
False
Filter by name
  • maxLength: 256
  • minLength: 1
schedule.uuid
string
query
False
Filter by schedule.uuid
schedule.name
string
query
False
Filter by schedule.name
scope.include_extensions
string
query
False
Filter by scope.include_extensions
scope.exclude_extensions
string
query
False
Filter by scope.exclude_extensions
scope.max_file_size
integer
query
False
Filter by scope.max_file_size
  • Max value: 1099511627776
  • Min value: 1024
scope.exclude_paths
string
query
False
Filter by scope.exclude_paths
  • maxLength: 255
  • minLength: 1
scope.scan_without_extension
boolean
query
False
Filter by scope.scan_without_extension
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan_on_demand]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "log_path": "/vol0/report_dir",
      "name": "task-1",
      "scan_paths": [
        "/vol1/",
        "/vol2/cifs/"
      "schedule": {
        "name": "weekly",
      "scope": {
        "exclude_extensions": [
          "mp3",
          "mp4"
        "exclude_paths": [
          "/vol1/cold-files/",
          "/vol1/cifs/names"
        "include_extensions": [
          "vmdk",
          "mp*"
        "max_file_size": 10737418240
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
Schedule of the task.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
boolean
Specifies whether or not files without any extension can be scanned.
svm
_links
_links
name
string
uuid
string
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path
string
The path from the Vserver root where the task report is created.
name
string
On-Demand task name
scan_paths
array[string]
List of paths that need to be scanned.
schedule
schedule
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
