Retrieve the OAuth 2.0 status
Retrieves the current status of OAuth 2.0, which helps you monitor and manage authentication processes within your environment.
HTTP method and endpoint
GET /security/authentication/cluster/oauth2
Introduced in
ONTAP 9.14
Usage notes
Retrieves the OAuth 2.0 status.
Related ONTAP commands
security oauth2 show
enabled |
boolean |
query |
False |
Filter by enabled |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
enabled |
boolean |
Indicates whether OAuth 2.0 is enabled or disabled globally. Default value is false. |
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
