REST API reference
Retrieve the OAuth 2.0 status
Retrieves the current status of OAuth 2.0, which helps you monitor and manage authentication processes within your environment.
HTTP method and endpoint
GET /security/authentication/cluster/oauth2
Introduced in
ONTAP 9.14
Usage notes
Retrieves the OAuth 2.0 status.
  • security oauth2 show
enabled
boolean
query
False
Filter by enabled
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
enabled
boolean
Indicates whether OAuth 2.0 is enabled or disabled globally. Default value is false.
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
