Retrieve the Duo group configured for an SVM or cluster
GET /security/authentication/duo/groups/{owner.uuid}/{name}
Introduced In: 9.14
Retrieves the Duo group configured for an SVM or cluster.
Related ONTAP commands
security login duo group show
owner.uuid |
string |
path |
True |
Account owner UUID. |
name |
string |
path |
True |
Group name. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
Comment for the Duo group. |
excluded_users |
array[string] |
List of excluded users. |
name |
string |
Name of the group to be included in Duo authentication. |
owner |
SVM name and UUID for which the Duo group profile is configured. |
"next": {
"href": "/api/resourcelink"
"comment": "string",
"excluded_users": [
"user1",
"user2"
"name": "AD_Group",
"owner": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
owner
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
