REST API reference
Retrieve the Duo group configured for an SVM or cluster
Retrieves the Duo group configuration for a specific SVM or cluster to review its settings and ensure proper authentication management.
HTTP method and endpoint
GET /security/authentication/duo/groups/{owner.uuid}/{name}
Introduced in
ONTAP 9.14
Usage notes
Retrieves the Duo group configured for an SVM or cluster.
  • security login duo group show
owner.uuid
string
path
True
Account owner UUID.
name
string
path
True
Group name.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
comment
string
Comment for the Duo group.
excluded_users
array[string]
List of excluded users.
name
string
Name of the group to be included in Duo authentication.
owner
owner
SVM name and UUID for which the Duo group profile is configured.
  "comment": "string",
  "excluded_users": [
    "user1",
    "user2"
  "name": "AD_Group",
  "owner": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
owner
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
