REST API reference
Retrieve the configured groups
Retrieves the configured groups to view the current group configurations in your setup.
HTTP method and endpoint
GET /security/authentication/duo/groups
Introduced in
ONTAP 9.14
  • security login duo group show
excluded_users
string
query
False
Filter by excluded_users
comment
string
query
False
Filter by comment
name
string
query
False
Filter by name
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[duogroup]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
        "next": {
      "comment": "string",
      "excluded_users": [
        "user1",
        "user2"
      "name": "AD_Group",
      "owner": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
SVM name and UUID for which the Duo group profile is configured.
_links
_links
name
string
uuid
string
duogroup
Group profile to include in Duo authentication.
_links
_links
comment
string
Comment for the Duo group.
excluded_users
array[string]
List of excluded users.
name
string
Name of the group to be included in Duo authentication.
owner
owner
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
