REST API reference
Retrieve the configured groups
Retrieves the list of configured groups to view their current settings and configurations. This allows you to manage and review authentication group setups efficiently.
HTTP method and endpoint
GET /security/authentication/duo/groups
Introduced in
ONTAP 9.14
Usage notes
Retrieves the configured groups.
  • security login duo group show
owner.name
string
query
False
Filter by owner.name
owner.uuid
string
query
False
Filter by owner.uuid
name
string
query
False
Filter by name
comment
string
query
False
Filter by comment
excluded_users
string
query
False
Filter by excluded_users
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[duogroup]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "excluded_users": [
        "user1",
        "user2"
      "name": "AD_Group",
      "owner": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
owner
SVM name and UUID for which the Duo group profile is configured.
_links
_links
name
string
uuid
string
duogroup
Group profile to include in Duo authentication.
comment
string
Comment for the Duo group.
excluded_users
array[string]
List of excluded users.
name
string
Name of the group to be included in Duo authentication.
owner
owner
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
