Retrieve an AWS KMS configuration
Obtains the AWS KMS configuration for a specified SVM, which is useful for managing encryption settings and ensuring secure data operations.
HTTP method and endpoint
GET /security/aws-kms/{uuid}
Introduced in
ONTAP 9.12
Usage notes
Retrieves the AWS KMS configuration for the SVM specified by the UUID.
Related ONTAP commands
security key-manager external aws show -
security key-manager external aws check
uuid |
string |
path |
True |
AWS KMS UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
access_key_id |
string |
AWS Access Key ID of the user that has appropriate access to AWS KMS. |
amazon_reachability |
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
default_domain |
string |
AWS KMS default domain. |
ekmip_reachability |
array[ekmip_reachability] |
encryption_context |
string |
Additional layer of authentication and logging. |
host |
string |
AWS KMS host's hostname. |
key_id |
string |
AWS Key ID. |
polling_period |
integer |
Polling period in minutes. |
port |
integer |
AWS KMS port. |
proxy_host |
string |
Proxy host. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
region |
string |
AWS region of the AWS KMS. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
service |
string |
AWS service type. |
skip_verify |
boolean |
Set to true to bypass verification of the user provided access_key_id and secret_access_key. An error will be returned if 'skip_verify' is provided but 'access_key_id' is not. |
state |
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide. |
svm |
timeout |
integer |
AWS Connection timeout, in seconds. |
uuid |
string |
A unique identifier for the AWS KMS. |
verify |
boolean |
Set to true to verify the AWS KMS host. |
verify_host |
boolean |
Set to true to verify the AWS KMS host's hostname. |
verify_ip |
boolean |
Set to true to verify the AWS KMS host's IP address. |
"href": "/api/resourcelink"
"access_key_id": "<id_value>",
"amazon_reachability": {
"code": "346758",
"message": "Amazon KMS is not reachable from all nodes - <reason>."
"default_domain": "domainName",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
"host": "aws-host.host.com",
"key_id": "kmip-aws",
"polling_period": 55,
"port": 443,
"proxy_host": "proxy.eng.com",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"region": "us-east-1",
"scope": "string",
"service": "dynamodb.*.amazonaws.com",
"skip_verify": "",
"state": {
"code": "346758",
"message": "AWS KMS key protection is unavailable on the following nodes: node1, node2."
"svm": {
"name": "svm1",
"timeout": 20,
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"verify": "",
"verify_host": 1,
"verify_ip": ""
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537551 |
Top-level internal key protection key (KEK) unavailable on one or more nodes. |
65537552 |
Embedded KMIP server status not available. |
65537915 |
The Amazon Web Service Key Management Service is unreachable from one or more nodes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
amazon_reachability
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster. |
message |
string |
Error message returned when 'reachable' is false. |
reachable |
boolean |
Set to true if the Amazon KMS is reachable from all nodes of the cluster. |
node
_links |
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
cluster_state |
boolean |
Set to true when AWS KMS key protection is available on all nodes of the cluster. |
code |
string |
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster. |
message |
string |
Error message set when cluster_state is false. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
