REST API reference
Retrieve an AWS KMS configuration
GET /security/aws-kms/{uuid}
Introduced In: 9.12
Retrieves the AWS KMS configuration for the SVM specified by the UUID.
  • security key-manager external aws show
  • security key-manager external aws check
uuid
string
path
True
AWS KMS UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
access_key_id
string
AWS Access Key ID of the user that has appropriate access to AWS KMS.
amazon_reachability
amazon_reachability
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
default_domain
string
AWS KMS default domain.
ekmip_reachability
array[ekmip_reachability]
encryption_context
string
Additional layer of authentication and logging.
host
string
AWS KMS host's hostname.
key_id
string
AWS Key ID.
polling_period
integer
Polling period in minutes.
port
integer
AWS KMS port.
proxy_host
string
Proxy host.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
region
string
AWS region of the AWS KMS.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
service
string
AWS service type.
skip_verify
boolean
Set to true to bypass verification of the user provided access_key_id and secret_access_key. An error will be returned if 'skip_verify' is provided but 'access_key_id' is not.
state
state
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide.
svm
svm
timeout
integer
AWS Connection timeout, in seconds.
uuid
string
A unique identifier for the AWS KMS.
verify
boolean
Set to true to verify the AWS KMS host.
verify_host
boolean
Set to true to verify the AWS KMS host's hostname.
verify_ip
boolean
Set to true to verify the AWS KMS host's IP address.
      "href": "/api/resourcelink"
  "access_key_id": "<AWS-ACCESS-KEY-ID>",
  "amazon_reachability": {
    "code": "346758",
    "message": "Amazon KMS is not reachable from all nodes - <reason>."
  "default_domain": "domainName",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
  "host": "aws-host.host.com",
  "key_id": "kmip-aws",
  "polling_period": 55,
  "port": 443,
  "proxy_host": "proxy.eng.com",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "region": "us-east-1",
  "scope": "string",
  "service": "dynamodb.*.amazonaws.com",
  "skip_verify": "",
  "state": {
    "code": "346758",
    "message": "AWS KMS key protection is unavailable on the following nodes: node1, node2."
  "svm": {
    "name": "svm1",
  "timeout": 20,
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "verify": "",
  "verify_host": 1,
  "verify_ip": ""
Status: Default
ONTAP Error Response Codes
Error Code Description
65537551
Top-level internal key protection key (KEK) unavailable on one or more nodes.
65537552
Embedded KMIP server status not available.
65537915
The Amazon Web Service Key Management Service is unreachable from one or more nodes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
amazon_reachability
code
string
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster.
message
string
Error message returned when 'reachable' is false.
reachable
boolean
Set to true if the Amazon KMS is reachable from all nodes of the cluster.
node
_links
_links
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
cluster_state
boolean
Set to true when AWS KMS key protection is available on all nodes of the cluster.
code
string
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster.
message
string
Error message set when cluster_state is false.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
