Retrieve an IPsec policy
Retrieves a specific IPsec policy to review its configuration and settings.
HTTP method and endpoint
GET /security/ipsec/policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
security ipsec policy show
uuid |
string |
path |
True |
IPsec policy UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
authentication_method |
string |
Authentication method for the IPsec policy. |
certificate |
Certificate for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
local_endpoint |
Local endpoint for the IPsec policy. |
local_identity |
string |
Local Identity |
name |
string |
IPsec policy name. |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
remote_identity |
string |
Remote Identity |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
Unique identifier of the IPsec policy. |
"authentication_method": "string",
"certificate": {
"href": "/api/resourcelink"
"name": "string",
"ipspace": {
"name": "exchange",
"local_endpoint": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24",
"port": "23"
"local_identity": "string",
"name": "string",
"protocol": "17",
"remote_endpoint": {
"family": "string",
"netmask": "24",
"port": "23"
"remote_identity": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257116 |
IPsec policy with the specified UUID was not found. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
local_endpoint
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
remote_endpoint
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
port |
string |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
