REST API reference
Retrieve an IPsec policy
GET /security/ipsec/policies/{uuid}
Introduced In: 9.8
Retrieves a specific IPsec policy.
  • security ipsec policy show
uuid
string
path
True
IPsec policy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
action
string
Action for the IPsec policy.
authentication_method
string
Authentication method for the IPsec policy.
certificate
certificate
Certificate for the IPsec policy.
certificate_modify_keepsa
boolean
Indicates whether old security associations are kept upon certificate modification.
enabled
boolean
Indicates whether or not the policy is enabled.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
local_endpoint
local_endpoint
Local endpoint for the IPsec policy.
local_identity
string
Local Identity
name
string
IPsec policy name.
ppk
ppk
Post-quantum pre-shared key information.
protocol
string
Lower layer protocol to be covered by the IPsec policy.
remote_endpoint
remote_endpoint
Remote endpoint for the IPsec policy.
remote_identity
string
Remote Identity
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
uuid
string
Unique identifier of the IPsec policy.
  "action": "string",
  "authentication_method": "string",
  "certificate": {
        "href": "/api/resourcelink"
    "name": "string",
  "ipspace": {
    "name": "Default",
  "local_endpoint": {
    "address": "10.10.10.7",
    "family": "string",
    "netmask": "24",
    "port": "23"
  "local_identity": "string",
  "name": "string",
  "ppk": {
    "identity": "string"
  "protocol": "17",
  "remote_endpoint": {
    "family": "string",
    "netmask": "24",
    "port": "23"
  "remote_identity": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
local_endpoint
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
port
string
Application port to be covered by the IPsec policy
ppk
identity
string
Post-quantum pre-shared key identity.
remote_endpoint
address
string
family
string
IPv4 or IPv6
netmask
string
port
string
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
