REST API reference
Retrieve TOTP profiles configured for user accounts
Retrieves the TOTP profiles configured for your user accounts to manage and review their two-factor authentication settings.
HTTP method and endpoint
GET /security/login/totps
Introduced in
ONTAP 9.13
Usage notes
Retrieves the TOTP profiles configured for user accounts.
  • security login totp show
comment
string
query
False
Filter by comment
scope
string
query
False
Filter by scope
enabled
boolean
query
False
Filter by enabled
account.name
string
query
False
Filter by account.name
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
sha_fingerprint
string
query
False
Filter by sha_fingerprint
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[totp]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "account": {
        "name": "joe.smith"
      "comment": "string",
      "enabled": "",
      "owner": {
        "name": "svm1",
      "scope": "string",
      "sha_fingerprint": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
account_reference
_links
_links
name
string
User account
owner
Owner name and UUID that uniquely identifies the TOTP profile.
_links
_links
name
string
uuid
string
totp
TOTP profile for the user account used to access SSH.
_links
_links
account
account_reference
comment
string
Optional comment for the TOTP profile.
enabled
boolean
Status of the TOTP profile.
owner
owner
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
SHA fingerprint for the TOTP secret key.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
