Retrieve TOTP profiles configured for user accounts
Accesses the TOTP profiles configured for user accounts to review and manage two-factor authentication settings.
HTTP method and endpoint
GET /security/login/totps
Introduced in
ONTAP 9.13
Usage notes
Retrieves the TOTP profiles configured for user accounts.
Related ONTAP commands
security login totp show
Learn more
scope |
string |
query |
False |
Filter by scope |
enabled |
boolean |
query |
False |
Filter by enabled |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
sha_fingerprint |
string |
query |
False |
Filter by sha_fingerprint |
account.name |
string |
query |
False |
Filter by account.name |
comment |
string |
query |
False |
Filter by comment |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[totp] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"account": {
"name": "joe.smith"
"comment": "string",
"enabled": "",
"owner": {
"name": "svm1",
"scope": "string",
"sha_fingerprint": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_reference
_links |
name |
string |
User account |
owner
Owner name and UUID that uniquely identifies the TOTP profile.
_links |
name |
string |
uuid |
string |
totp
TOTP profile for the user account used to access SSH.
_links |
account |
comment |
string |
Optional comment for the TOTP profile. |
enabled |
boolean |
Status of the TOTP profile. |
owner |
Owner name and UUID that uniquely identifies the TOTP profile. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
SHA fingerprint for the TOTP secret key. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
